Mastercam X9 HLE (Home Learning Edition) Crashing
By
KartEnthusiast, in Educational Forum
DanielGingras 3,471
Hello,
What are the specifications of your computer? What is your operating system, graphics card model, how much RAM do you have, etc.
One thing to try is to go to Windows Start > All Programs/Apps > Mastercam X9 Demo-HLE > Advanced Configuration, then look for Graphics Support and disable hardware acceleration.
1
I'm using an HP Pavillion g6 laptop. OS: Windows 7 Home Premium; Graphics Card: None; RAM: 4.00 GB (3.80 GB usable); System Type: 64-bit Operating System; CPU: Intel Core i3.
I tried disabling the hardware acceleration, and it still doesn't open.
DanielGingras 3,471
Hello,
Try deleting your config file. For the HLE you should be able to find it here:
C:\Users\YourUsername\Documents\my mcamDemoHLEx9\CONFIG
The file you want to delete is mcamx.config
Let me know if that works!
1
I deleted mcamx.config and it still doesn't work.
DanielGingras 3,471
Do you have any Windows updates pending? If so, install those and then see if Mastercam functions.
Radical1 25
I seem to be having a similar problem with a laptop, MasterCAM opens but after I draw a couple of rectangles or any geometry, a notification comes up saying that the display driver has stopped responding and has recovered but all I can do is close mastercam.
specs are as follows
HP envy notebook
6th gen. I7
16GB RAM
Win 10
4 GB NVIDIA GTX graphics dedicated
I have tried disabling hardware acceleration (not that I should have to with these specs) but no difference.
This a brand new computer.
DanielGingras 3,471
Hello Radical1,
Are you using Windows 10 home or pro?
Are there any updates for your Nvidia drivers available?
You may also need to update .NET framework to a newer version.
Finally, does your laptop also have integrated graphics in addition to the GTX card?
79rr79 0
My company just bought the mill essentials book and it came with the x9 home learning edition. I am trying to install it on my home pc, everything seems to install fine but when it launches it crashes instantly. In the log the crash says McUex:Mastercam raised an Unhandled Exception. Looking at the system requirements I have windows 7 home premium (requires professional) and my video card is an Intel G45/G43 (definitely not right), but would this cause the error I am seeing?
Not missing anything On board graphics are NOT supports
https://www.mastercam.com/en-us/Support/System-Requirements
Video OpenGL 3.2 support with 512 MB memory. No onboard graphics
79rr79 0
I had x7 installed and everything worked fine.
DanielGingras 3,471
Hello 79rr79,
You might be able to get it to work by disabling graphics hardware acceleration.
If that doesn't work it's possible the computer isn't able to run X9, either due to the hardware or the operating system.
Radical1 25
Hello Radical1,
Just an update to my issue, I found that the computer was running both onboard intel graphics AND NVIDIA graphics the NVIDIA graphics were not running MasterCAM, that is why the Intel graphics were crashing. I had to go to the graphics setup and use NVIDIA graphics all the time.
Thanks Daniel for the help.
Richard
79rr79 0
Update on my problem
Installed a PNY - GeForce GT 610 2GB DDR3 graphics card and so far everything seems to be good.
Timakey1 0
How do I get NViidia Geforce to run when using the MastercamX9 demo. My picture freezes or does respond any help i would be grateful
Recently Browsing 0 members
Hello to whomever reads this,
I am a student just beginning learn Mastercam. I am using Mastercam X9 HLE (Home Learning Edition) and it worked for a few weeks with no problem. Now it doesn't even open and directs me to the crash report message in the picture I uploaded. I have submitted the forms in the crash report twice and nothing happened. I have also tried uninstalling and re-installing it, but it still sends me to the crash report. Anyone have any advice on how to get it running again?
My sincerest thanks,
KartEnthusiast
