Curve Driven Pattern? Rotate with Z move?
Bcasteel
Does anyone know of a good way to pattern/transform operations for something that needs to both rotate and move along an axis. all of the cuts are the same. currently we use a translate between planes for each cut sometimes hundreds of pattern operations (also trying to prevent lots of tool changes) but i was wanting to find a better method.Helix.jpg
yea that is what i was hoping to avoid 33 pockets each with a bunch of operations then circular pattern it 3 times. we make a couple parts like this each week i was just hopeful that a faster way existed in Mastercam in Solidworks its a nice easy curve driven pattern.
Also i like your signature!
Yea we recently started using the multi-axis drilling operation and that has cut down on the total number of operations. Unfortunately i am unable to share the model due to company policy's
so from the sounds of it we probably are already doing it the most efficient way. programing one cut then transforming it to all the rest then doing the final transform but it can get confusing on some of the parts.
the only other idea i had was maybe with a custom post edit and using the custom parameters fields in a rotate transform i could get and axis move between each instance but that might be a question for my re-seller.
If you do this a couple of times a week, I'd have a template file set up with my tools/speeds/feeds/doc's etc and all depths set to inc.
Then just select the geo as per JP said and copy rotate.
John/Everyone - what about the ATP add-on? Would that help in any way?
Edit - would a custom CHook help - if this was that repetitive it maybe worth the time creating?
To the best of my knowledge, ATP is geared towards routers but designed cut cutting mainly flat panel type things....
Layout your flat geometry on specific levels, then those levels can be picked up and certain toolpaths then applied.
Think Cabinetry and all the panels required
I am not certain it would be of any use on something like this...
