Available levels of MasterCam?
jmk021083
On the mIll side it used to be;
  • Mill Entry (Contour Pocket and Drill)
  • Mill Level 1 (all the above plus Wireframe Toolpaths, Rotary substitution, and the High Speed 2D Toolpaths)
  • Mill Level 2 (all the above plus single surface machining)
  • Mill Level 3 (all the above plus multi-surface machining and high speed toolpaths)
  • Mill 5-Axis  (I belive all the above plus 4 and 5-Axis)
On the Lathe side it use to be;
  • Lathe Entry (turning paths only)
  • Lathe Level 1 (all the above plus C-Axis paths)
Then of course the add-ons.
THis is an old list it may or may not still be accurate.
James, That list is outdated. The levels now are basically Mill 2D, 3D, Curve/Drill 5 Axis, Multi axis. Not sure how the lathe is structured because I started with the mill side of things and added lathe.
  • 3 months later...
On 11/12/2016 at 11:13 AM, Jay Kramer @ Precision Programming said:
Ben it is Mill Entry, Mill and Mill 3d there is no Mill 2d as that used to be level 1. now Mill is a equivalent to what was a Mill level 2 .
Lathe is Lathe Entry and Lathe.
What does it take to upgrade from Mill to Mill 3d?   Just a different dongle plugged in,  minus a big check?
One thing I know for sure..
Solids is no longer an upcharge, it is now standard .
I know this because I recently  opened a old V9 file containing a complex solid model
The file would open and the solid regened OK, but the Solids Manager was unavailable
because my full boat MC2017 net hasp does not contain a stand alone solids license
X8 was the last version that required a stand alone solids license, it's been built in since then
