VBScript for setting up fixture plate
'//        Author:   Jesse T.
'//       Credits:   Mick George [email protected] (I learned from his examples)
'//          Date:   06/2016
'//     File Name:   Fixture Plate Setup.vbs
'//   Description:   This script Imports solids and moves them to fixture locations
' Constants
Const ZZero = 0
Const Origin = 0
Const TopView = 1
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
' Variables
Dim intLevelNumber
Dim iX, iY, SetDistX, SetDistY, intCountX, intCountY
Dim File_or_Level
Dim Sort_or_Center
Dim SetAngle
Dim NumParts
' -- Initialize
SetAngle = 0
SetDistX = 2.0
SetDistY = 2.0
intCountX = 2
intCountY = 2
intLevelNumber = 2
NumParts = 0
' -- Ask our user for some values
   File_or_Level = askYesNoCancel("This VB Script will help you set up multiple parts on a fixture plate."_
     &VbCrLf&"""CANCEL"" if you want to exit this VBScript."_
     &VbCrLf&"""NO"" if your parts are on seperate LEVELS and the file is already open"_
     &VbCrLf&"""YES"" if your parts are in seperate FILES"_
     &VbCrLf&VbCrLf&"		FILES	          LEVELS	    CANCEL")
  If File_or_Level = 0 Then
   Sort_or_Center = askYesNoCancel("If you want to move your parts to center select ""YES"""_
     &VbCrLf&"If you want to layout a fixture plate select ""No"""_
     &VbCrLf&VbCrLf&"   Parts NOT on center     Parts on center    CANCEL")
  End If
   If File_or_Level = -1 Then Exit Sub
   If Sort_or_Center = -1 Then Exit Sub
  If Sort_or_Center = mcMSG_NO Then
   If Not askValue("Do you have to rotate the part?", -360 , 360, SetAngle) Then Exit Sub
  End If
   If Not askNumber("How many Parts along the X axis?", 1 , 50, intCountX) Then Exit Sub
   If Not askNumber("How many parts along the Y axis?", 1 , 50, intCountY) Then Exit Sub
   If Not askValue("Input X spacing of Parts", 0 , 20, SetDistX) Then Exit Sub
   If Not askValue("Input Y spacing of Parts", 0 , 20, SetDistY) Then Exit Sub
   ' -- Do some math
   Redim Preserve arrPartPosX(intCountX*intCountY)
   Redim Preserve arrPartPosY(intCountX*intCountY)
      For iY = 0 To intCountY - 1
         For iX = 0 To intCountX - 1
         arrPartPosX(NumParts) = (iX * SetDistX)-(((intCountX-1)*SetDistX)/2)
         arrPartPosY(NumParts) = (-(iY * SetDistY))+(((intCountY-1)*SetDistY)/2)
'ShowString "Part# "& NumParts + 1 &" = "& arrPartPosX(NumParts)&", "&arrPartPosY(NumParts)
         NumParts = NumParts + 1
	     Next
      Next
   Call Run_Script (NumParts, arrPartPosX, arrPartPosY, intCountX, intCountY, intLevelNumber, File_or_Level, Sort_or_Center, SetAngle)
End Sub
' The Sub that does it all
Sub Run_Script (NumParts, arrPartPosX, arrPartPosY, intCountX, intCountY, intLevelNumber, File_or_Level, Sort_or_Center, SetAngle)
Dim YLoc
Dim XLoc
Dim strLevelName
Dim Revert_Back
Redim Preserve arrLevelUsed(intCountX*intCountY)
'Loads files and translates into fixture locations
If File_or_Level = mcMSG_YES And Sort_or_Center = mcMSG_NO Then
          ShowString "Please select a starting level, parts will load in sequential levels"
          If askLevel(intLevelNumber) Then
   ' -- Rotate and Position Parts
      For NumParts = 0 To (intCountX*intCountY) - 1
      strLevelName = "Position #" & NumParts + 1
        If mc_appversion < 19 Then 'Renames levels if MCam is older than 2017 Version
         Call SetLevelName (intLevelNumber, strLevelName)
        End If
   	     YLoc = arrPartPosY(NumParts)
         XLoc = arrPartPosX(NumParts)
         arrLevelUsed(NumParts) = intLevelNumber
             SetLevelVisibleByNumber intLevelNumber, False
             SelectAll()
             SetLevelByNumber (intLevelNumber)
             Call RepaintScreen(True)
             Call RunMastercamCommand ("DoPattern")
             SetLevelVisibleByNumber intLevelNumber,True
             Call RunMastercamCommand ("GSInvertSelection")
If StartDBSearch(mc_selected, -1)= 0  Then NumParts = (intCountX*intCountY) - 1
             Rotate Origin, Origin, Origin, SetAngle, False
             SelectAll()
             Call Move_to_location(XLoc, YLoc, NumParts)
         intLevelNumber = intLevelNumber + 1
      Next
          End If
End If
 ' -- Clear and Zoom All
  UnselectAll()
  Call ClearMenuAndPrompts
'Translates individual levels into fixture locations
If File_or_Level = mcMSG_NO And Sort_or_Center = mcMSG_NO Then
          SelectAll()
          SelectAll()
        End If
   Next
End If
  UnselectAll()
'---- Unsorts individual parts to center
If Sort_or_Center = mcMSG_YES Then
   	  YLoc = -arrPartPosY(NumParts)
      XLoc = -arrPartPosX(NumParts)
        If AskForEntity("SELECT PART #"&numparts+1,-1) Then
          arrLevelUsed(NumParts) = GetEntityLevel()
          Rotate Origin, Origin, Origin, - SetAngle, False
        End If
   Next
End If
  UnselectAll()
Revert_Back = askYesNo("Do you want to keep these new locations?")
'---- Reverses Translated individual levels back to original locations
If Revert_Back = mcMSG_NO Then
      intLevelNumber = arrLevelUsed(NumParts)
Else
End If
          SelectAll()
          SelectAll()
   Next
End If
  UnselectAll()
If askYesNo("Repeat the same setup?") = mcMSG_YES Then
End If
End Sub
' Sub Declaration
Sub Move_to_location(XLoc, YLoc, NumParts)
Const DEF_GIVE_ME_EVERYTHING = -1
Dim bRet
bRet = StartDBSearch(mc_selected, DEF_GIVE_ME_EVERYTHING)
   If bRet Then
     Do
       ' Change the location of each "selected" entity that we find.
       Call Translate (Origin, Origin, Origin, XLoc, YLoc, ZZero, TopView, TopView, False)
       bRet = NextDBSearch
     Loop While bRet
   End If
' Like it says...
UnselectAll()
End Sub
I accidental deleted my original post.  Here is an updated version that has more options. (This one works MUCH better).
This script will sort or un-sort parts into a grid so they can be cut on a fixture plate.  The reason I made this is because we typically get .X_T files of several parts that are pretty much the same except for cavity numbers or stacking lugs.  Sometimes we'll get a single file with each part on it's own level, other times we'll get each individual part in it's own .X_t file.  I feel I don't contribute enough to this forum to make up for how much help I've received. Hopefully this script will help someone else out.
Just copy and paste the code into a text file and save that file as "Fixture Plate Setup.vbs" then run within MasterCam.
  • Like 5
