Change "I" to "Q" for G73 cycle
Good Morning
I'm trying to edit our Haas post to use a Q instead of an I when posting out G73 drill cycles. It uses I,J,K values in G83, but when it posts out a G73 cycle it still uses the "I" address, with no J or K, and this alarms out the machine. Currently, this is where I am looking at the cycles:
      if haas,        [        result = nwadrs(stri,peck1$)        result = nwadrs(strj,peck2$)        result = nwadrs(strk,peckclr$)        ]    pbld, n$, sgfeed, e$prdrlout        #R drill position      if absinc$ = zero, refht_a, !refht_i      else, refht_i, !refht_apdrlxy          #Drill XY coordinates      if force_dpts, pfxout, pfyout      else, pxout, pyoutpdrill$          #Canned Drill Cycle      pdrlcommonb      pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,        prdrlout, [if dwell$, *dwell$], *feed, strcantext, e$      pcom_moveappeck$           #Canned Peck Drill Cycle      pdrlcommonb      pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,        prdrlout, *peck1$, [if haas, *peck2$, *peckclr$], *feed, strcantext, e$      pcom_movea
pchpbrk$         #Canned Chip Break Cycle      pdrlcommonb      pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout, pindexdrl,        prdrlout, *peck1$, *feed, strcantext, e$      pcom_movea
I can see where it assigns the IJK addresses to the peck1$ and peck2$ variables at the top. My thought would be to have some logic where if it sees it's posting G73, to re-assign "Q" to peck1$ before, or possibly just re-assign the "Q" within the pchpbrk$ postblock.
I'm still really green with all of this, having only been going through the MP Guide for a day or so. Any help is appreciated!
- Frank
-Update-
I was able to make it work by re-assigning the address for peck1$ within the pchpbrk$ postblock. Here is my fix:
      pdrlcommonb
        prdrlout, result = nwadrs(strq,peck1$), *peck1$, *feed, strcantext, e$
      pcom_movea
If this is not proper form or if anyone has a better way to do this please let me know. Thanks.
Yes it is good,
just don't forget to bring back the proper address for other canned cycles.  If I read properly, your G83 will need peck1$ to be assigned letter I.
Regards,
Correct. I only changed it within the chipbreak postblock. For G83 cycles I tested it and it still works, assigning IJK values to peck1$ and peck2$.
Thanks, Martin!
