2D High Speed single parameter call out, please help.
Hello everyone,
   I'm trying to call out my High Speed 2DToolPaths but somehow I got error messages.  I think I got the right parameter numbers from 2017 post parameter and perhaps I did something funky when I define it.   Please help and below here is what I did.
Thank you for your help
13 May 2017 10:28:35 AM - PST LINE (765) - Question number is not valid (1. to 999999999.)
13 May 2017 10:28:35 AM - PST LINE (766) - Question number is not valid (1. to 999999999.)
13 May 2017 10:28:35 AM - PST LINE (767) - Question number is not valid (1. to 999999999.)
13 May 2017 10:28:35 AM - PST LINE (768) - Question number is not valid (1. to 999999999.)
13 May 2017 10:28:35 AM - PST LINE (769) - Question number is not valid (1. to 999999999.)
13 May 2017 10:28:35 AM - PST LINE (5120) - Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (5121) - Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (5122) - Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (5123) - Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (5124) - Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6894) - The post block output type processing has failed!, , Label has not been defined[10]
13 May 2017 10:28:35 AM - PST LINE (6894) - The post block output type processing has failed!, , Label was expected but was not found[16], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6894) - The post block output type processing has failed!, , Label was expected but was not found[36], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6895) - The post block output type processing has failed!, , Label has not been defined[7]
13 May 2017 10:28:35 AM - PST LINE (6895) - The post block output type processing has failed!, , Label was expected but was not found[13], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6895) - The post block output type processing has failed!, , Label was expected but was not found[33], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6896) - The post block output type processing has failed!, , Label has not been defined[7]
13 May 2017 10:28:35 AM - PST LINE (6896) - The post block output type processing has failed!, , Label was expected but was not found[14], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6896) - The post block output type processing has failed!, , Label was expected but was not found[34], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6897) - The post block output type processing has failed!, , Label has not been defined[7]
13 May 2017 10:28:35 AM - PST LINE (6897) - The post block output type processing has failed!, , Label was expected but was not found[13], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6897) - The post block output type processing has failed!, , Label was expected but was not found[33], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6898) - The post block output type processing has failed!, , Label has not been defined[7]
13 May 2017 10:28:35 AM - PST LINE (6898) - The post block output type processing has failed!, , Label was expected but was not found[13], Illegal character(s) encountered
13 May 2017 10:28:35 AM - PST LINE (6898) - The post block output type processing has failed!, , Label was expected but was not found[33], Illegal character(s) encountered
2DCore: 0
2DPeel: 0
2DBlend: 0
2DArea: 0
2DRest: 0
DynamicArea: 0
DynamicRest: 0
DynamicCore: 0
DynamicContour: 0
HighSpeed2DToolPathsContour: 0
fmt      4  2DCore
fmt      4  2DPeel
fmt      4  2DBlend
fmt      4  2DArea
fmt      4  2DRest
fmt      4  DynamicArea
fmt      4  DynamicRest
fmt      4  DynamicCore
fmt      4  DynamicContour
fmt      4  HighSpeed2DToolPathsContour
pwrttparam$ #Information from parameters
            if prmcode$ = 12713,
		         2DCore = rpar(sparameter$,0)
			  2DPeel = rpar(sparameter$,1)
			  2DBlend = rpar(sparameter$,2)
			  2DArea = rpar(sparameter$,3)
			  2DRest = rpar(sparameter$,4)
			  DynamicArea = rpar(sparameter$,5)
			  DynamicRest = rpar(sparameter$,6)
			  DynamicCore = rpar(sparameter$,7)
			  DynamicContour = rpar(sparameter$,8)
pHighSpeed2DToolPaths
	   if 2DCore = 1, "(", *HighSpeed2DToolPathStepOver, "STEPOVER, ", *HighSpeed2DToolPathStepOverCoreMill, no_spc$, "% TOOL DIA.)", e$
	   if 2DPeel = 1, "(", *HighSpeed2DToolPathStepOver, "STEPOVER, ", *HighSpeed2DToolPathStepOverCoreMill, no_spc$, "% TOOL DIA.)", e$
	   if 2DBlend = 1, "(", *HighSpeed2DToolPathSBlendStepOver2, "STEPOVER, ", *HighSpeed2DToolPathStepOverCoreMill, no_spc$, "% TOOL DIA.)", e$
	   if 2DArea = 1, "(DYNAMIC AREA)", e$
	   if 2DRest = 1, "(DYNAMIC REST)", e$
	   if DynamicArea = 1, "(DYNAMIC CORE)", e$
	   if DynamicRest = 1, "(DYNAMIC CONTOUR)", e$
	   if DynamicCore = 1, "(DYNAMIC CONTOUR)", e$
	   if DynamicContour = 1, "(DYNAMIC CONTOUR)", e$
ptlchg_com      #Tool change common blocks
ptlchg0$         #Call from NCI null tool change (tool number repeats)
Why do you keep making this so hard on yourself? All those long variables one letter out of place and it will mess everything up. You should learn the KISS process for your work. Keep It Simple Stupid not that you're stupid, but make the process so simple that anyone can use do it and understand it. Your variables are just to long and sorry, but time I try to make sure each letter is exact for each one I have put way more time into helping you than I am willing to do for free. Best of luck and hope you work in a shop where you can post and go with your code and not have to coddle the people running your programs.
you have two problems.  You are using rpar incorrectly is the first issue.  The second issue is the parameters values in the documentation are not correct.  my guess is they were not updated when the the toolpaths were consolidated a few versions back.  Below are the values for the toolpaths I tested.   I am unsure of of the "2D area" style toolpaths output.  this has been reported but hopefully this helps.
  • if prmcode$ = 12713, my_variable = rpar(sparameter$, 1)
    • Dynamic set to stay inside = 0
    • Dynamic set to from outside = 0
    • Dynamic rest = 0
    • Dynamic contour = 2
    • Dynamic peel = 3
    • 2d blend = 4
    • Any other toolpath = -99999
    • Dynamic rest = 0
    • Dynamic peel = 3
    • 2d blend = 4
Thank you for your suggestions, I truly appreciated.
