rename nciname by toolgroup name
vb.net 2008 X5
how can i do rename nciname by toolgroup name,below code run fail,thanks
          For Each groups As Mastercam.Support.Group In Mastercam.Support.SearchManager.GetGroups()
               For Each op_s As Mastercam.Database.Operation In SearchManager.GetOperations
                   op_s.NCIName = group_name & Str(intCount) & ".NCI"
                    op_s.Commit()
                    If (op_s.Dirty) Then
                        op_s.Regenerate()
                    End If
               Next
               intCount = intCount + 1
           Next
12 hours ago, Roger Martin from CNC Software said:
Could we get a bit more information here? Any errors?
What are the specific types of the toolpath operation you are trying to .Commit?
no any error,all operation nci name are same last group name, I want rename operation nci by group name
Toolpath Group-1  nci name Toolpath Group-1.nci
Toolpath Group-2  nci name Toolpath Group-2.nci
Toolpath Group-3  nci name Toolpath Group-3.nci
Toolpath Group-4  nci name Toolpath Group-4.nci
..etc.
thanks
This code tested in Mastercam X9 (using the NETHook3_0 API).
It is possible that it may not work in older versions.
Imports System.IO
Imports Mastercam.Support
Namespace ChangeToolpathName
    Public Class ChangeNCI
        ''' <summary> Change the NCI/NC output name in the selected operations. </summary>
        ''' <param name="onlySelectedOps"> (Optional) True to only process 'selected' operations, false to do all of the ops. </param>
        ''' <returns> The number of operations that were altered. </returns>
        Public Function ChangeName(Optional onlySelectedOps As Boolean = False) As Integer
            Dim count = 0
            Dim ops = SearchManager.GetOperations(onlySelectedOps)
            For Each op As var In ops
                ' Find the Group this Operation is in and then get the Name of that Group.
                Dim groupNumber = op.GroupNumber
                Dim group As Mastercam.Support.Group = GroupManager.FindGroupByID(groupNumber)
                ' Get the output folder path.
                Dim nciPath = Path.GetDirectoryName(op.NCIName) + "\"
                ' *** NOTE ***
                ' A Group Name could contain characters that are invalid for a path\name!
                ' We are NOT doing any checking for that situation here!
                ' Build up the new toolpath output file name.
                Dim newPath = nciPath + group.Name + ".NCI"
                op.NCIName = newPath
                ' Older Mastercam may not have this true/false parameter on .Commit()
                If op.Commit(False) Then
                    count += 1
                End If
            Next
            Return count
        End Function
    End Class
End Namespace
Edited by Roger Martin from CNC Software
Imports System.IO
            Dim count = 0
                ' *** NOTE ***
                    count += 1
                End If
            Next
            Return count
        End Function
    End Class
End Namespace
Roger isn't that really the best move to update and get with current coding methods and processes? X5 wow that is going back to the either 32bit or 64bit possibility of coding.
On 20.5.2017 at 7:39 PM, Lee1 said:
vb.net 2008 X5
                    op_s.Commit()
                        op_s.Regenerate()
                    End If
               Next
           Next
X+ ;)
