Yasnac MX1 parameters set up HELP!
Please help.
I have an Acroloc series 10 with a yasnac MX1 and was sitting in storage for about 17 years. Finally got it working manually but I cannot get the controller to let me set the parameters even after I set the thumbwheel to "1" and parameter line #6219 or #6259 (this one worked for our MX3) . Any thoughts? Which positions do you set the mode switch to? Is there anything else that needs to be done to unlock the parameter settings? Thank you , any help would do.
If the thumbwheel is set to 1 then you should be able to write parameters. IIRC on the MX1 you have to type in the entire line, you can't just edit one bit. Type the entire block of characters and press the WR key. Some parameters require that the machine is powered down in order for them to take.
