Copy Area Mill Bug?
ahaslam
I might have found a bug in 2018. Does anyone want to take a look at this for me? In the op2 group, I created an area tool path then decided to copy the toolpath to do a rest machining operation. The copied tool path has been rendered useless. Even after unnecessarily reselecting the geometry I couldn't get a valid path. The bug stands out when you click "preview chains" button (reference the Z2G). I will work around by creating a new path as opposed to copying but has this been reported already?
13999 DOOR SURFACING 30IN CUBE 110885.ZIP
On 6/26/2017 at 4:27 PM, ajmer said:
check the stepover of the copied operation
sometimes it doesn't update and keeps the large stepover of the initial roughing tool
I did go back through and check all that prior to posting this. Did you not have the same issues?
ahaslam,
See the attached file.  When I downloaded your file it appears you had the same size tool loaded for the second area mill operation.  I think that was your issue.  I recreated the operation and picked your 1/4 inch tool and I believe it should give you the toolpath you are looking for.
13999 DOOR SURFACING 30IN CUBE 110885 CL.zip
