Rotate geometry to align with selected line
I have a VBScript that creates a group of lines and arcs that are aligned with an existing line. I am in the process of converting that script into a VB NETHook. My problem is after I create that group of lines and arcs I need to align them with the existing line that was selected to position the group.
I have created the code that creates the group of lines and arcs:
    '///////////////////////////// create a new group of lines & arcs ////////////////////////////////////////////////////////////////////
                 Create_line(0.0 + entity.Data.Point1.x, 0.0 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z,
                                    0.0 + entity.Data.Point1.x, 0.2622 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, intLevel)
                Create_Arc(-0.2 + entity.Data.Point1.x, 0.2622 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 360, 484.2289, intLevel)
                Create_Arc(-0.425 + entity.Data.Point1.x, 0.5929 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 180, 304.2289, intLevel
                Create_line(-0.625 + entity.Data.Point1.x, 0.5929 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z,
                                    -0.625 + entity.Data.Point1.x, 0.9071 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, intLevel)
                Create_Arc(-0.425 + entity.Data.Point1.x, 0.9071 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 55.7711, 180, intLevel)
                Create_Arc(-0.2 + entity.Data.Point1.x, 1.2378 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 235.7711, 360, intLevel)
                Create_line(-0.0 + entity.Data.Point1.x, 1.2378 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z,
                                    0.0 + entity.Data.Point1.x, 1.4622 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, intLevel)
                Create_Arc(-0.2 + entity.Data.Point1.x, 1.4622 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 360, 484.2289, intLevel)
                Create_Arc(-0.425 + entity.Data.Point1.x, 1.7929 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 180, 304.2289, intLevel)
                Create_line(-0.625 + entity.Data.Point1.x, 1.7929 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z,
                                    -0.625 + entity.Data.Point1.x, 2.1071 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, intLevel)
                Create_Arc(-0.425 + entity.Data.Point1.x, 2.1071 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 55.7711, 180, intLevel
                Create_Arc(-0.2 + entity.Data.Point1.x, 2.4378 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, 0.2, 235.7711, 360, intLevel)
                Create_line(0.0 + entity.Data.Point1.x, 2.4378 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z,
                                    0.0 + entity.Data.Point1.x, 2.7 + entity.Data.Point1.y, 0.0 + entity.Data.Point1.z, intLevel)
    '///////////////////////////// create a new line ////////////////////////////////////////////////////////////////////
    ' sub to create a line (start x1,start y1,start z1,end x2,end y2,end z2)
    Public Sub Create_line(X1point As Double, Y1point As Double, Z1point As Double, X2point As Double, Y2point As Double, Z2point As Double, intLevel As Integer)
        Dim newLine = New LineGeometry
        With newLine
            .Data.Point1 = New Point3D(X1point, Y1point, Z1point)
            .Data.Point2 = New Point3D(X2point, Y2point, Z2point)
            .Level = intLevel
            '.Color = RGB(1, 1, 240)
            .LineStyle = LineStyleType.Solid
            '.PointStyle = PointStyleType.Square
            .Commit()
        End With
        GraphicsManager.Repaint(True)
    End Sub
    '///////////////////////////// create a new arc /////////////////////////////////////////////////////////////////////
    ' sub to create an arc (center x, center y, center z, radius, startangle, endangle, level)
    Public Sub Create_Arc(Center_x As Double, Center_y As Double, Center_z As Double, Rad As Double, Start_angle As Double, End_Angle As Double, intlevel As Integer)
        Dim newArc = New ArcGeometry
        With newArc
            .Data.CenterPoint.x = Center_x
            .Data.CenterPoint.y = Center_y
            .Data.CenterPoint.z = Center_z
            .Data.Radius = Rad
            .Data.StartAngleDegrees = Start_angle
            .Data.EndAngleDegrees = End_Angle
            .Level = intlevel
            '.Color = RGB(100, 255, 255)
            .Commit()
        End With
    End Sub
I also have the code to get the angle of the selected positional line:
                Dim angle = VectorManager.AngleDegrees(New Point2D(entity.Data.Point2.x - entity.Data.Point1.x, entity.Data.Point2.y - entity.Data.Point1.y))
What I need help with is what Mastercam API object can I use to align the group of lines and arcs to the same angle as the line the user selected to position that group of lines and arcs.
              Thank you
