Rectangular Broach
Here we do a ton of flanges for microwave applications. Usually we get away with being able to put a .015 radius in the corner but one customer is insisting on .008 max. The parts are over .200 thick so I'm thinking a .016 endmill over 10x diameter might be a small challenge and time consuming. Our Haas VF2 has the spindle orient option so I can program it to orient at any angle. I would like to broach the rectangle to size while forming the corner radii. The size is pretty small .140 X .280 with a +/-.001 tolerance. I would mill the slot to with in .003-.005 with a .047 endmill leaving a .0235 radius in the corner to broach out. Has anyone done anything like this? I have seen a bunch of keyway broaching while researching this but nothing really like the application I am looking at broaching a rectangle. The feature is through and the material is Aluminum.
Thinking about something like this custom made for the size we need. Place to purchase?
  • BrianP. changed the title to Rectangular Broach
Brian,
I did a TON of this while at Cobham/Kevlin Microwave.....
Slater Tools....find a broach that is the right size...
I would use a drill path and after milling down to .0235 rad, I would draw a line out of each corner at 45°....break it into as many points as I wanted and create points at endpoint....then pick them in the order to approach the corner....done, square corner...use can use a .005 step early, then drop to a .002 with a free pass or 2...(hint-disable Filter out duplicates to get free passes....
Edited by Guest
1 hour ago, mkd said:
haven't worked microwave parts since the mid 90's. Used to love those .02" pocket floor thicknesses, flat within .002:wub:
Never broached on a haas mill but iv'e always  been  paranoid about the servo dithering when "locked"
Yeah. Everything is +/-.001 and true position of .002-.005. Even the clearance holes for screws. Frickin engineers. :P
