Lathe custom form thread
K20
52 minutes ago, JParis said:
I'll bite...whatcha' got?
You need to put dwell on
the lenght and pitch are in the misc
Control depth of pass in peck and depth of cut
To finish give only one passe in peck and depth of cut but change the whith of pass from % to step amount
Always keep dwell to  1 or more
and unselect finish
I dont have an nc simulator but the code is tested
Do you know a good freeware to test nc codes?
Give me feedback
NOW IN ENGLISH
THREADENG .pst
THREADENG .mcam-lmd
custom thread.mcam
Edited by K20
CORRECTION TO ENGLISH
I have said it before and will say it again: this should be a standard feature of Mastercam :) I use a macro B program for special threading, but a custom post sounds like more fun. Thanks for sharing for free!
Remember to put the tool to a small tilt to avoid rubbing with the back of the tool.
  • 11 months later...
K20,
I appreciate that you've been able to hack the Post to get the output that you want. But using the "Dwell" parameter, is the wrong way to go about making this work. What you've done is to "break" the Dwell function, for any other section of the Post that would use it to output an actual "Dwell" command.
Here is the original Dwell Post Block:
pdwell1         #Dwell output
      gcode$ = four  #for implied dwells
      pcan1, pbld, n$, *sgcode, *dwell$, strcantext, e$
Here is the block that you've hacked to get the output you want for this specific task:
      pbld, n$, "G32", *mr1$, psgcode, *mr2$, e$
      #if gcode$ = four
      #pbld, n$, "G32", "mr1$","*mr2$", e$
      #pbld, n$, "G32", "-"*dwell$, *pffr, e$
      #pbld, n$, *psgfeed, e$
      #pbld, n$, "G00", e$
I don't want to discourage you from learning how to edit a Post, as that is something I think every serious CNC Programmer should learn how to do. But there is also a "right way", and a "wrong way" to make your edits. I consider any edits that "break" other functions in the Post to be the "wrong way" to edit a Post.
Also, do you realize you "broke" the Incremental Calculations for X and Z output?
Here is the original Format Assignment block:
fmt  "N" 24  n$           #Sequence number
fmt  "X" 2  xabs        #X position output
fmt  "Y" 2  yabs        #Y position output
fmt  "Z" 2  zabs        #Z position output
fmt  "U" 3  xinc        #X position output
fmt  "V" 3  yinc        #Y position output
fmt  "W" 3  zinc        #Z position output
fmt  "C" 11 cabs        #C axis position
fmt  "H" 14 cinc        #C axis position
fmt  "C" 11 cout_a      #C axis position
fmt  "H" 14 cout_i      #C axis position
I put a carriage return after the "absolute" and "incremental" variables, to help you see that these 3 absolute variables (xabs, yabs, and zabs) and the three incremental variables (xinc, yinc, zinc), must remain in a "ordered list" (implied array of variables). When you move the variables out of position, or insert a new variable at the beginning, middle, or end of the list, you break any of the "vector math functions" that expect an ordered list of variables. Vector Add, and Vector Subtract functions use a single "input" variable, that indicates the beginning of a list of "3 ordered variables".
Here is your Format Assignment section:
fmt  "N" 4  n$          #Sequence number
fmt  "Z" 2  zinc        #Z position output
fmt  "W" 3  mr1$        #Z position output
fmt  "I" 3  iout        #Arc center description in X
fmt  "J" 3  jout        #Arc center description in Y
fmt  "K" 3  kout        #Arc center description in Z
fmt  "R" 2  arcrad$     #Arc Radius
By moving "zinc" above "xinc", and adding your own new Format Assignment for MR1, you've changed the way that the Incremental values will be calculated. The most dangerous part of this, is the fact that 'zinc' will never get its value set by this code:
#Incremental calculations
ps_inc_calc     #Incremental calculations, start
      xia = fmtrnd(xabs)
      yia = fmtrnd(yabs)
      zia = fmtrnd(zabs)
      xinc = vsub (xia, prv_xia) #This line calculates all three incremental variables: xinc, yinc, and zinc, with Vector Subtract!
By editing the placement of your variables in the "ordered list", that function will now set: xinc, yinc, and mr1$. (So, zinc never gets set!)
You could do the following, which would at least not "break" the incremental functions:
Again, I'm not trying to discourage you from making Post Edits that serve your needs, but I'm very worried with this statement you made: "I can also edit Posts for other controls". By making the edits the way that you are, you're honestly causing more harm than good.
17 minutes ago, Colin Gilchrist said:
Hello Collin, i know my way of making this post was UN ortodox but i hade to get code fast for a job.
This post is intended for one and only thing : Shape threading.  I dont work post every day.  But it was the simplest, fastest way i did it.
Thank you for the remarks.
And sorry getting myself in your expertise.
Kevin
Quote
Made several parts with this.................................... Kev
And never asked a dime for the work.
K20,
      #if gcode$ = four
      xia = fmtrnd(xabs)
      yia = fmtrnd(yabs)
      zia = fmtrnd(zabs)
Totally agree with you !
ive been able to program a cable drum in MCAM with a button insert using a bunch of G33 but the math + the chaining behind was a PITA to do
47 minutes ago, K20 said:
Maybe Colin Gilchrist could make us one No Charge.
I was juste trying to help.....
I completely get that you're trying to be helpful. I didn't mean my critique to be insulting, and I hope you don't take it that way. I get that you're trying to accomplish something with the Post that Mastercam doesn't currently support.
All that said, I think it is dangerous for anyone to have to hand-edit their NC Code, and producing a Post that breaks a fundamental Post Mechanism, just to get output for a specific application, is not the way I like to develop Posts. My main concern was you saying i CAN ALSO EDIT POST TO OTHER CONTROLS .
To me, that is a dangerous statement to make, when you are simply hacking the Post, so that it works for one specific application only, and you are breaking a feature of the Post to get the output you need.
Look, I get it. I often have to make a compromise on doing a job "the right way", and having someone tell me to "just get it done", so I end up taking a shortcut.
You've got a total of 8 posts on this forum, of which, 7 of those posts are in this particular thread. So please forgive me if I've offended you, but look at it from my perspective: I am simply trying to warn anyone who might be interested in using your "free Post", of exactly what it will do, and more importantly what it won't do.
I think you'll find that I've given plenty of "free" advice, help, and/or Posts to this forum. That includes having taught a completely free version of my Basic Post Class, a couple years back.
I am currently doing this with a grooving tool path.
1. I use “Depth Cuts” so that I only get positioning moves.
2. I make sure that “Groove Walls” is set to “Steps” so that I only get positioning moves.
3. I use “Absolute” for my retract value to clear the threads when positioning.
4. I activate “Dwell Time” so that I have a separate line that I can convert to threading.
5.This only works with a roughing path.
Ok,
When I post to Cimco,
I shift the entire rough groove operation by a given amount so that I position in front of the stock.
Then I Replace my dwell line (G4 P1000)  with my Thread Z Finish Value & Thread Pitch  (G32 Z-5.35 F.500)
20 minutes ago, jlw™ said:
Orvie, could you save a step and just shift your groove geo to output the Z values you want?
The way I do it, the groove path respects the stock.
If I put the geometry in front of the stock, I wouldn't be able to create a finish cycle.
This material is usually inconel.
By having leftover stock, I can create a second threading operation with smaller stepovers for cleaning up just the walls.
Without stock recognition, the finish passes would cut a lot of air and take way too long.
I've tried this many ways.
ORVIE
-Copy your groove in an other level
-Cut the groove pattern in multi segment about the sise of scallop you want
-Use the same groove path tweaking the step over for finish scallops
-use stock
-In depth make 2 passe (seems it yont clear stock in 1 passe)
- Made a ZIP TO GO at the end.
Sheers
Rugh finish no air time
image.thumb.png.b6758305262dd25d3d4d25e1e9037adb.pngimage.thumb.png.bde8430e077d6126b0acbe2d1871ee1e.png
GROOVE.ZIP
  • 7 months later...
สวัสดี K20 มากขอบคุณฉันพยายามที่จะแก้ปฐมวัยโพสต์นี้เป็นเวลา 10 ปีสร้างโปรแกรมของที่คุณคุณเอง แต่ไม่ประสบความสามารถสำเร็จจนกว่าที่คุณคุณจะเห็นพระเจ้าโปรดชัดเจน ....
Edited by aekky-1992
  • 2 months later...
  • 1 year later...
