Transform a Trasnform and add to WCS for each
Codeworx
I'm either missing something or this is not possible. Sample is mill default but I'm using a MPmaster based post.
I am trying to use Transform > Transform and make the output WCS for each position +1. G54.1 P11 to G54.1 P19
I'm able to get the first 5 positions but the last three don't increase (something is wrong in second transform).
I know I could make geometry to replace first transform and transform that but my file already has 300+ operations as is and adding 4 operations for each path is not ideal.
TIA
Transform Transform offset NUmbers.mcam
2 hours ago, JParis said:
Check out the settings I changed in the transforms
Toolplane should be in use.....
https://www.dropbox.com/s/svu2mowsjxbpso3/JP_Transform Transform offset NUmbers.mcam?dl=0
Also from the 2nd transform I unchecked the ghosted OP...in the way the 1st one is set up you don't need to transform that OP with it
I had coordinate set because the base position is center of fixture(sorry forgot to mention it in original post), so all the positions need different output and different offset. Otherwise I would just use a subprogram.
Also when using Toolplane Rotate throws an error in MPMaster
