So not a Guru
Making 2018 the default open application
Does anyone know how to get Windows 7 to change the default open application for .mcam files from 2017 to 2018? Trying to set the default thru control panel doesn't work.
Some times it's best to ad a send to option rather than open with.
Gcode had a post about how to do it. It may show if you do a search
4 minutes ago, Leon82 said:
right click, open with choose default program?
No, that was what I tried 1st
Hmm, I always have difficulty using this sites search function. I've searched using several different phrases, but I just get "no results found". I even tried 2017 to 2018, nada.
I know there is a way to get it done in the registry, I just haven't found the correct spot yet.
I know I'm a year late, but here is the solution :
right click on a .mcam file, choose open with, select default program, browse, navigate to C:\Programe Files\Common Files\Mastercam and select McamVersionSelector.exe
  • Thanks 2
Update 2020 and 2019 still wants to be the default, even if I pick it from the program folder it still go back to 2019?
As Jaco mentioned above you need to set it to open with "McamVersionSelector Executable" To do this first go to the start menu and search for "choose default apps by file type" this should take you to your file type list, then set .mcam to be opened with the "McamVersionSelector Executable"
My coworker is having this problem but its not with his .mcam, its his .step files are opening in 2018. He just mentioned it the other day and I tried to change it and no luck, it just kept reverting to 2018. I go into that default apps by type, and it doesn't give him the option to select McamVersionSelector Executable. Any other ideas?
do you still need 2018 on the system? Cuz if you dont use that version you could uninstall it, so only mastercam 2020 is installed. Then set your Open with options to use Mastercam.exe for any .step file. If there is only one version of mastercam on the pc then that is the only version it will be able to open it with. That would be the easiest fix so if you only use the latest version removing the old version wold be an easy fix to prevent it from opening with that older version.
That's because it sucks.
  • Haha 1
