frankr54
Posting Setup Sheet Variables
I hope I get this all right, this is my first post here.
I would like to incorporate some of the Setup Sheet information into my part programs (project #, part #, rev., etc.).
Is it possible to extract this info via variables in the post?
I know I can prompt for inputs during the posting process (and have done this), but this has to be repeated each time I post the job.
Any help is appreciated.
I find the easiest way to accomplish this is to use a Manual Entry "Toolpath" as the "First Operation" in the Ops Manager in Mastercam. This way you can type in the "comments" inside the Manual Entry path, and then make an easy Post Mod (saving the "1008" Operation Comment" during "Pheader" processing, and outputting the Saved Op Comment inside "psof$"), so you can have your Setup Info (from Manual Entry), then your Tool List, and finally your Start of File codes, with Operation Comment.
If you are looking to "Capture the data from the Active Reports data entry fields, then I'm not sure you can do that inside the PST File...
you can put question in your post procesor,
so before that the g code is generated the machine can question you like PROGRAM NUMBER,PART NUMBER so once that you put hte information the g code is generated with your ifnormation
This: Note2Post?
Hi Peter, it appears as though your CHook needs post mods.  You might consider making the null values not output with a simple comparison.  Just a thought but it does look like it would benefit many people.
Hi,  I'm new to post editing. Could you show an example of how it should look in the post please?
I've shown this probably half a dozen times over the years. Do a search in the Post Development forum. Try the following:
sopcomm
sop_comm
15240
Operation Comment
if gcode$ = 1008
One of those search terms should yield some results.
