How To Force Alternate 5 Axis Combination?
McLaren
 Trying to figure this out and hopefully someone can help me. Mastercam 2018 is posting out
B-8.253 C0.
X10.8407 Y3.1385
But I don't have enough 'X' travel so I want to go
B8.253 C180.
X-10.8407 Y-3.1385
Any thoughts? I went into my plane manager and edited the plane by spinning the gnomon 180°, but that didn't help. Thanks in advance for any and all replies!
Can you tell your machine def that you can only rotate so far in either direction?
I have to do that for our 5ax trunnion. By default it can go -30 to +110 deg. But I have to tell it 0 to +110 because it's pretty close to my X+ travel limit, this makes the rotation change.
B-8.253 C0.
X10.8407 Y3.1385
B8.253 C180.
X-10.8407 Y-3.1385
Some posts have a "bias angle" is the misc variables. I don't have much success with them, but you can try.
1 hour ago, K2csq7 said:
Sometimes you can get around this with "Limits" in the multiaxis paths, if the misc values don't help.
MT has a  checkbox on the setup branch "use alternate B axis solution" for this situation.
I'm using Dynamic OptiRough. It's a 3+2 toolpath
1 hour ago, jeff said:
What is the B- limit value set at? Or am I way off base here.
It's at B-35 B+110. The problem is I have valid B-10.000 movements that don't need to be fixed. If nothing else I will limit 'B' in the mmd file. Just was hoping for a better path by path solution.
1 hour ago, TheePres said:
With Hass trunnion I control this with misc "primary bias". I'm not at computer so don't recall exact value I use. Try 0,1,2..see if gets you needed code
Looks like our post doesn't have this :(
Also, check the Post Switch "adj2sec". That stands for "adjust to secondary", and gives the Post Processor the ability to "flip the Primary 180".
Last thing,
The "mi10$" switch can be used to "disable" negative or positive range from the Secondary, on a "per operation" basis. So you could simply set it to "2" for "Positive only", for that Operation. Since the Secondary is "limited" and "can't go negative", it should force "C180 B+".
On 2/20/2018 at 1:49 PM, C^Millman said:
What is the toolpath? There are limits in the toolpaths, but really going to come down to what toolpaths and process you are doing to see what might be the best method to help. Where did you get your post? Can go back to the post builder and ask them to add this ability.
 Toolpath is 2D Dynamic Mill. Post is from In-House Solutions. Sounds like we definitely need to have this ability added.
On 2/20/2018 at 1:57 PM, Colin Gilchrist said:
You should be able to control this with "mi4$ and mi5$", for that particular Operation. If this is a "Null Tool Change" Op, then you must enable "bias_null" switch inside the Post.
You should just have to plug in "180" for the Primary (mi4) and "8.253" for the Secondary (mi5).
No such misc. integers.
Last thing,
Again, no such misc. integer.
What post are you using for this machine
these are standard features in the Generic Hass Trunion post that ships with Mastercam
# Features:
# This post supports Generic 5 axis milling.
# It is designed to support the features of Mastercam X Mill
# Following Misc. Integers are used:
# mi2 - Absolute or Incremental positioning at top level
#        0 = absolute
#        1 = incremental
# mi3 - Select G28 or G30 reference point return.
#        0 = G28, 1 = G30
# mi4 - Start initial primary rotary axis bias
#       +/-999 represents start as close to limit as possible
#       0 represents calculate without using bias
#       Any other value represents an angle in degrees to attempt
#       to position near.
#        -999 = Low, 0 = Off/Default, 999 = Hi, Value = Angle bias
# mi5 - Start initial secondary rotary axis bias
#       to position near.
Yes, you need to talk with In-House Solutions, since they are the ones that built your Post Processor.
Have you read through the Post Processor Header, to read the comments at the top of your Post? Most Posts have comments at the top that describe the features of the Post, and the "controls" that are built into the Post, like the Misc. Integers and Real Numbers. These Parameters can be used by the Post to control output.
Quote
# mi4 - Calculated 5-Axis Angles
#         0 = -A Solution
#         1 = +A Solution
this is a cut and paste from an old InHouse 5X post I have here
This is for  a JOBS C/A head head gantry mill, but I would expect to see something similar in your post
  • 4 years later...
9 minutes ago, serge.lavor said:
Hello all here, I am new to MasterCAM and currently running 2022 version. And having exact same problem, I want my C axis be 180 flipped. But my Misc menu is different to the one you guys showed above. Please help, how do I force my C axis to be flipped?
You should post a Ziptogo file, it is easier and also shows you are a legitimate user of Mastercam.
That looks like a Factory Thermwood Post. Reach out to those guys they can help you in no time. Ask them to give you the PDF explaining all of the different feilds so you know how to make the adjustments you need. They claim they don't have one then tell them they owe you one. I suspect mi1 or mi2, but can't be sure.
