Feed Rate At the same tool
Hello everyone,
   I would like to make the feed rate appear on the second toolpath with same tool and I tried to use "*"/ "~" but it appeared feed for all lines.  Is there away that it only appear on the first line?  Please see detail below.  Thank you for your help.
Thank for your time to read this.
N8( .5000,1/2 EM, CB, ROUGHER,)
(3FLTS 1.000LOC, 1.25STO)
G0 G17 G40 G49 G80 G90
G91 G28 Z0 M19
G28 Y0
T8 M6(ROUGH AND FINISH 4X .8125 'CBORES, CUT#12)
G90 G54 X-9.8438 Y-10.
S7500 M3
(RAMP ANGLE= .5 DEGGREE)
G43 H8 Z1. T9 M8(DOC= Z-.625)
Z.0313
G1 Z0. F200. ============================> First tool change is good
X-9.8457 Y-9.9756 Z-.0002
(CUTTING...)
X-10.067 Y10.0401 Z-1.9991
X-10.0741 Y10.0248 Z-2.
G3 X-9.9219 Y10. R-.0781
X-10.0741 Y10.0247 R.0781
G0 Y10.0248 Z1.
N9(FINISH 4X THRU .531 HOLES, CUT#14)
G0 G90 G54 X10.061 Y8. (PROGRAM JUMP HERE)
G43 H9 Z1.(DOC= Z-2.)
X10.061 Y8. S7500 M3
(XY STK= .0015)
(RAMP ANGLES= 3. DEGGREES)
Z.0313
G1 Z0.  ============================> Feed Rate is missing here, it should be G1 Z0. F200
X10.0591 Y8.0152 Z-.0008
X10.0535 Y8.0294 Z-.0016
(CUTTING...)
X-10.06 Y-8.0108 Z-1.9992
X-10.0553 Y-8.0257 Z-2.
G3 X-9.939 Y-8. R.061
X-10.0553 Y-8.0257 R-.061
G0 Z1.
M9
G91 G28 Z0.
/G28 Y0. M5
M1
T8 M6(FIRST PROGRAMMED TOOL)
M30(604,147CHARS - 606.12KB)
3 hours ago, So not a Guru said:
You aren't outputting a toolchange (no M6) at the 2nd tool. That's probably why it isn't reposting the feed. What post are you using?
Hi Guru,
  I'm using the emastercam forum stock post. I would like not do perform a tool change, is the a way to put the feed for it?
Thanks.
