Macro B question
MIL-TFP-41
I dug around and can't find the answer to this
I want to make a statement saying something like this:
If #3 and #18 are not equal to #0 then go to N400
would the correct format be this?
IF[#3AND#18NE#0]GOTO400
I dug around in a bunch of Renishaw macros & could't find anything like that. There was some that looked like this:
IF[#3AND18NE#0]GOTO400
So the # sign is missing from the 18
What would be the correct way?
23 hours ago, JParis said:
IF[#3NE#0]AND[#18NE#0]GOTO400
I think that'll get it
OK, I tried that & got an illegal expression alarm.
It did take both this IF[#3AND#18NE#0]GOTO400 and IF[#3AND18NE#0]GOTO400
however.....It didn't react as I hoped so back to the drawing board
#0 is typically an un-assignable NULL or 0. value used in MTB "stuff."  At least, every Fanuc based control I've had my hands on. I typically try to use all #500 and higher as you get down into the variables the MTB and probe use down in the #0 to #199 area.  I have generally had bad luck with #0 and I always just assign one such as #599=0. for my use.
Then you should be able to use what John offered but subbing #599 for #0.
In my experience any way, hope that helps.
I got it worked out. Later in the program there is a line, IF[#18EQ#0]THEN#18=0.
The fanuc's read ahead even when you turn high speed off with a G5.1Q0, so it was giving R or #18 a value of zero when it hit that statement ( IF[#3AND#18NE#0]GOTO400 ), even tho the program had not progressed to that point.
So I changed it to read if #3 and #18 had a value other than zero, an error came up. Got it working...so all is well.
11 hours ago, Tim Johnson said:
I ended up doing that also. Renishaw told me what it was but I forgot. (2002?) They told me to comment it and see if that worked. It did.
We have 1604 bit zero on and the install guys put the g5.1q0 in the settings sub program.
But the ots macro where it spins the tool to touch off isn't working. The guy is coming to look at it but I may try turning the parameter off to see if it makes a difference
