3 hours ago, Günther Massimo - GMCCS said:
X+ is updated for Mastercam 2019.
download
Awesome!  Now I can officially start using 2019! :lol:
anyone seeing a crash issue launching X+ tool list? 2018 and 2019
mine started today, worked fine last week. nothing was updated
It's working fine on my 2018 box
setup sheet etc. work fine, just the tool list is crashing
Do you have Tl manufactor selected? If so, change it to Tl Mfg code. It was change in 2018.
i just ran the windows update, working now
download
Is it possible to add misc integers or reals to the output of X+ setup sheets?
download
Hi Gunther
Trying to use the attached template file but it causes MC2019 to crash every time. This is a new template that I created through x+ in MC2019, but is laided out exactly the same as we have been using for the last few versions.
default - McClay.template
13 hours ago, MrFish said:
Hi Gunther
Your template works fine on my system.
Make sure the "Manufaturer name" of your tools is set. It shouldn't be empty!!!
I need to check this parameter to avoid a crash. It is already on my to do list ;)
Hi Gunther
Yes filling in the tool manufacturer name worked. Removing this from our selection to be displayed also worked.
This did used to work fine in all the previous versions before MC2019 without the tool manufacturer being filled in, it would just leave the space blank and not cause a crash.
For us we have a lot of tools in our library where the tool manufacturer was not filled out due to the very limited selection mastercam used to have.
Anyway love the product and look forward to the fixed version when you get around to it. In the mean time I will just run without the tool manufacturer column
Thanks Mark
11 hours ago, Günther Massimo - GMCCS said:
It should work now.
download
Works a treat. Much appreciated Gunther.
Thanks Mark
Hi Gunther .
I finally got around to try the Add Fixtures C-hook.  Adding a fixture with this user interface is good , but I'm thinking that , with one little add on , you could make this very simple but  very  effective c-hook be applcable to other  file based geometry .  I would be very interested in using your interface for mold design.  Until now I have used Merge, for this but if you added  the same kind of placement interface as Merge has then  this tool would be even more universal.
Also , if you could post a link to the video describing this  c-hook again , I would be very obliged.  I tried a search on this site but could not find it....
Gracjan
On 24.4.2018 at 11:33 PM, Joe6Pack said:
Is there a way to change the field headers other than to edit the dll?
https://github.com/thadseaver/xplus-rename
or
Use the CSS Styles
/* renaming column names */
/* hide all column names */
.CONTENT_TABLE th
	text-indent: -9999px;
	line-height: 0;
/* add a new style to display new names */
.CONTENT_TABLE th:after
	text-indent: 0;
	line-height: initial;
	display: block;
/* set the new column name for "Group Name" */
.th_27:after {
	content:"Grp Name";
/* set the new column name for "Prog Name" */
.th_32:after
		content:"NC Name";
/* set the new column name for "tl no" */
.th_72:after
	content:"T\0023";
/* set the new column name for "tl dia" */
.th_62:after
	content:"T\00F8";
  • Thanks 2
Gunther,
I downloaded the zip file to my desktop, my trend micro flags it as ransomware but I ignore the message to block the install and click allow. After I agree to the Terms it tries to install but I get "Mastercam Directory not found\Installation aborted" message. I've used your application since the beginning and it usually just installs without issues. Am I doing something wrong? Please help if you can.
I have a windows 7 pc.
image.png.fb4394d3843e85e9f7e16189d310a759.pngimage.png.c76aed1ee0d10e857cb33807686570e1.png
Hi Gunther,
For some reason, I cannot extract the Setup X+_2019_en.exe app and run to install.  The fixtures app installs perfectly.
Anybody else having a problem like this?
I am running WIndows 7 pro.
Thank you
Finally got around to setting up the Fixtures utility. Excellent little utility. Thanks heaps for producing and sharing this Gunther.
