MASTERCAM API'S (net-hooks using vb.net)
Hi, I am  a student
Sorry if its a silly thing to ask!I am very new to mastercam API'S. I have learnt fundamentals of vb.net and want to work with mastercam API'S  for my project. I followed the PDF instructions(Mastercam.net API's Developing vb.net add-ins for mastercam) which links mastecam interface to vb.
I viewed through (mastercam vb.net examples files ) for example codes but unable to understand much.
I am trying to create "points and lines" but unable to do so.
I tried to mimic the code from example files but it didn't show anything on mastercam when I debugged the program.
The attachments which I included with this post are the ones which I mimicked from the examples files
Can anyone help me with  the problem
Thanks in advance
On our website are sample NET-Hook projects:
https://www.mastercam.com/en-us/Communities/3rd-Party-Developers/NET-Hook-Downloads
You appear to be missing the main "Run" function that Mastercam calls when you run your Add-In. From within the "Run", you call your methods.
Public Overrides Function Run(ByVal param As Integer) As MCamReturn
    Me.Point1()
    Return Mastercam.App.Types.MCamReturn.NoErrors
End Function
Rogin Martin and Mick George, thanks a lot for replying to my query.
I added that "run function" which calls the "point1() and point2()" subs. When I ran the program it opened mastercam but nothing appeared in it
I added break points  to understand the code but it popped up a message.
I am attaching the  screenshots(which I took while the program was running) . I have also attached my vb.net project(masternethook.rar).
Can you guys tell me where I went wrong this time?
masternethook.rar
Your NET-Hook works for me. It created the two points.
Be sure the you are running the proper DLL (masternethook.dll) that this project created?
In your “The breakpoint will not currently be hit” screen shot, Visual Studio is referring to -> OPERATIONSMANAGEREXMAPLE.DLL
That’s not the name of the DLL that the “masternethook“ project you sent creates.
I loaded your “masternethook“ project in Visual Studio.
Start Debugging (F5) and Mastercam 2018 starts up.
Selected the “Run Add-In” command and navigated to the bin\Debug folder of the “masternethook“ project and selected the just built masternethook.dll.
The result is two points added to the Mastercam database and shown on-screen.
That SplineGeometry constructor wants an array of Point3D objects.
See the online NET-Hook API docs here ->
https://nethookdocs.mastercam.com
Dim pt1 As New Point3D(10, 0, 0)
Dim pt2 As New Point3D(10, 10, 10)
Dim pt3 As New Point3D(25, 30, 35)
' Need an Array of Point3D objects
Dim points() As Point3D
points = New Point3D() {pt1, pt2, pt3}
Dim spline As New SplineGeometry(points)
spline.Commit()
Edited by Roger Martin from CNC Software
"Declaration expected" ?
What is the exact pop-up message?
The code below works for me. It creates the Spline and displays a message box -> "spline has 3 points"
(Visual Studio 2015 or 2017 and .NET Framework 4 or higher.)
Public Class MyHook : Inherits NetHook3App
        Dim spline = CreateSpline()
        MessageBox.Show(String.Format("spline has {0} points", spline.NodePoints.Length))
        Return MCamReturn.NoErrors
    End Function
    Private Function CreateSpline As SplineGeometry
        Dim points() As Point3D = {pt1, pt2, pt3}
        ' The "New Spline" in the parameter here is not needed.
        ' You can do it this way, it's just an unnecessary additional construction.
        'Dim spline As New SplineGeometry(New Spline(points))
        ' You can pass the points directly to the SplineGeometry constructor.
        Dim result = spline.Commit()
        Return spline
        End Function
End Class
Thanks sir, The  spline geometry worked
Sir, Iam unable to  understand that MC view on "mirror method  using MC views and line 3D" . I have written
(1): Line to be mirrored
(2): Axis on which the line is mirrored
(3): New mirrored line which is  the first line coordinates and return the new  mirrored line
(4): Call the function to the main run program
The code shows no error but, its not displaying the mirrored line5acdb14b02854_Screenshot(178).thumb.png.fe8154f8d8c95161a900bf2752016315.png
Please post your code, not "pictures" of your code.
Also, which version of Mastercam are you using?
This creates a mirrored line with endpoints of -10,0,0 and -10,10,0
      Dim result = MirrorLine()
      MessageBox.Show(String.Format("Line has been mirrored -> {0}", result))
  End Function
  Private Function MirrorLine() As Boolean
      Dim originalLine = New LineGeometry(New Point3D(10, 0, 0), New Point3D(10, 10, 0))
      Dim axisLine = New Line3D(New Point3D(0, 0, 0), New Point3D(0, 25, 0))
      Dim view = ViewManager.CPlane
      Return originalLine.Mirror(axisLine, view)
  End Function
Translation of a point or line
Sir  I've been trying to translate a point using the following code
Here's my code:
   Dim newpoint=translatepoint()
Private function  translatepoint() as boolean
Dim firstpoint=New pointgeometry(newpoint3D(0,0,0))
Dim transpoint=New point3D(15,25,30))
Dim Fromview as MC view
Dim Toview as MC view
return transpoint.translate(firstpoint,transpoint,fromview:=,Toview:=)
I don't  know what variable to assign to the arguments in return statement
Does MC view  ask for machine coordinates?
Sir If I have to give chaining and toolpath geometry for a component using mastercam APIs how should I proceed.  Can you give me some guidance on this.
I have attached a .mcam file of a component which I want to machine using mastercam APIs. The part is made in 'CATIA' and is imported into mastercam via ".stp" format.
Thanks in Advance
part x2.mcam
Translating geometry, see below.
As for "here is a part file, tell me how to do this..."
You'll need to email us with our data and your company ID -> [email protected]
      Dim result = TranslatePoint()
      Dim arc = TranslateArc()
      ViewManager.GraphicsView = SearchManager.GetSystemView(SystemPlaneType.Iso)
      GraphicsManager.FitScreen()
  End Function
  Private Function TranslatePoint() As Boolean
      Dim myPoint As New PointGeometry(1, 2, 0)
      Dim fromPoint As New Point3D(0, 0, 0)
      Dim toPoint As New Point3D(15, 25, 30)
      Dim fromView = ViewManager.CPlane
      Dim toView = SearchManager.GetSystemView(SystemPlaneType.Front)
      ' Translates (moves) the Geometry object
      Dim result = myPoint.Translate(fromPoint, toPoint, fromView, toView)
      Return result
  End Function
  Private Function TranslateArc() As ArcGeometry
      ' Create an arc at the origin in the current Construction Plane
      Dim myArc As New ArcGeometry(ViewManager.CPlane, New Point3D(0, 0, 0), 5, 0, 180)
      myArc.Commit()
      ' A copy the original eobject (myArc), then translate it.
      ' The new translated object is returned
      Dim newArc = myArc.CopyAndTranslate(fromPoint, toPoint, fromView, toView)
      Return newArc
  End Function
End Class
Sir, thanks a lot for your reply on my query on 'translating geometry'
Sir, I am having troubles while calling files from mastercam
I created dynamic 'button' and an ' open file dialog ' to allow me to open files within mastercam
Here's my code
#Creating buttons and openfile dialog#
<Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()>
Partial Class MainView
    Inherits System.Windows.Forms.Form
    'Form overrides dispose to clean up the component list.
    <System.Diagnostics.DebuggerNonUserCode()>
    Protected Overrides Sub Dispose(ByVal disposing As Boolean)
        Try
            If disposing AndAlso components IsNot Nothing Then
                components.Dispose()
            End If
        Finally
            MyBase.Dispose(disposing)
        End Try
    End Sub
    Private components As System.ComponentModel.IContainer
    <System.Diagnostics.DebuggerStepThrough()>
    Private Sub InitializeComponent()
        Me.OKButton = New System.Windows.Forms.Button()
        Me.openfilebutton = New System.Windows.Forms.Button()
        Me.openfiledialog = New System.Windows.Forms.OpenFileDialog
        Me.SuspendLayout()
        'OKButton
        Me.OKButton.Anchor = System.Windows.Forms.AnchorStyles.Right
        Me.OKButton.Location = New System.Drawing.Point(449, 300)
        Me.OKButton.Name = "OKButton"
        Me.OKButton.Size = New System.Drawing.Size(111, 48)
        Me.OKButton.TabIndex = 14
        Me.OKButton.Text = "OK"
        Me.OKButton.UseVisualStyleBackColor = True
        'openfilebutton
        Me.openfilebutton.Anchor = System.Windows.Forms.AnchorStyles.Top
        Me.openfilebutton.Location = New System.Drawing.Point(100, 155)
        Me.openfilebutton.Name = "openfilebutton"
        Me.openfilebutton.Size = New System.Drawing.Size(120, 50)
        Me.openfilebutton.TabIndex = 13
        Me.openfilebutton.Text = "Open"
        'MainView
        Me.AutoScaleDimensions = New System.Drawing.SizeF(9.0!, 20.0!)
        Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font
        Me.ClientSize = New System.Drawing.Size(669, 377)
        Me.Controls.Add(Me.OKButton)
        Me.Controls.Add(Me.openfilebutton)
        Me.Margin = New System.Windows.Forms.Padding(4, 5, 4, 5)
        Me.Name = "MainView"
        Me.Text = "MainView"
        Me.ResumeLayout(False)
    End Sub
    Private WithEvents OKButton As System.Windows.Forms.Button
    Private WithEvents openfilebutton As System.Windows.Forms.Button
    Private WithEvents openfiledialog As System.Windows.Forms.OpenFileDialog
# For opening dialog box using open file button I created#
 Private Sub OKButton_Click(sender As Object, e As EventArgs) Handles OKButton.Click
        Me.Close()
    End Sub
    Private Sub Openfilebutton_Click(sender As Object, e As EventArgs) Handles openfilebutton.Click
        If openfiledialog.ShowDialog() = DialogResult.OK Then
            openfiledialog.FileName = ""
        End If
#Main run function#
  Using view = New MainView()
            view.ShowDialog()
        End Using
When I run the add-in,  'Main form appears without the buttons', Can you help me with this
Thankyou
This question is basic .NET which we really don't do.
We're here to help you using Mastercam functionality in a Mastercam Add-In.
I created a simple VB.NET Windows Form Application, then I inserted your MainView.Designer.vb code.
The result worked for me. I get a somewhat large Form with (2) buttons.
Click on the 'Open' button and the File Open Dialog opens.
Click on the 'OK' button and the Form closes.
If you are just setting up the user interface for a NET-Hook add-in and
you are not really using any Mastercam “specific” functionality yet.
You can save time by building your project as a std. “Window Form Application”.
Then you don’t need to startup Mastercam, just to run your project to test your UI.
Once you get your UI setup like you want, just switch the Application Type over to “Class Library”,
and add a Reference to the NETHook3_0.DLL and have a class with the “Run” function in your project ->
Imports Mastercam.App
Imports Mastercam.App.Types
Public Class NethookMain
            view.ShowDialog()
        End Using
    End Function
End Class
Now you have a NET-Hook add-in (DLL) and can continue on to implementing the items that rely on Mastercam functionality.
WindowsAppVB.zip
Sir,  Thanks a lot  for helping me with the UI earlier.
Sir, I am having trouble with generating a bounding box .I know  the syntax is asking for an array, but  don't know what to assign for "Geometry to bound " as geometry()
Can I  get some help with this?
thanks in advance
ORIGINAL SYNTAX:
Public Shared Function RectangularBoundingBox (
	CommonData As BoundingBoxCommonParams,
	RectangularData As BoundingBoxRectangularParams,
	GeometryToBound As Geometry()
) As Geometry()
MY SYNTAX
 Public Shared Function RectangularBoundingBox() As Geometry()
        Dim solid As BoundingBoxCommonParams
        solid.CreateSolid = True
        Dim rectangle As BoundingBoxRectangularParams
        rectangle.ExpandXMinus = 20
        rectangle.ExpandXPlus = 10
        rectangle.ExpandYMinus = 50
        rectangle.ExpandYPlus = 30
        rectangle.ExpandZMinus = 0
        rectangle.ExpandZPlus = 40
        Dim geometrytobound As Geometry()
        geometrytobound
        Return
    End Function
 Private Sub Isometric_Click(sender As Object, e As EventArgs) Handles Isometric.Click
        Dim view As GraphicsViewType = GraphicsViewType.Iso
    End Sub
Sir , I am facing troubles  with enumerations. I am trying to call  enums from "graphicviewtype" enumerations but nothing worked.
Is something wrong with my code?.
Can you please help?
Thanks  in advance
