Create tool path fail for vb.net
With X5 (which is a sunsetted = no longer a supported version), what I can do here is very limited.
A quick look at the code that is run when you click the OK button, shows issues...
1> No geometry is created for the rectangle because the corner points you calculate are both X0,Y,Z0.
        Dim ss As Double
        'If mcUnit = mcUnit Then
            ss = 1 'Uncomment this line and the rectangle will now be created.
                       '*As long as you've entered valid values for the (3) items on your Form!*
        'Else
        '    ss = ss / 25.4
        'End If
        Dim i, j, k As Integer
        ' ss = 0 here, so the resulting i,j,k values become 0 !
        ' CreateRectangle fails to create anything because both corner pointsare 0,0,0
        i = (Int(TX.Text) / 2) * ss : j = (Int(TY.Text) / 2) * ss : k = (Int(TZ.Text)) * ss
        Dim topRectangle = GeometryCreationManager.CreateRectangle(New Point3D(i, j, 0), New Point3D(-i, -j, 0))
2> So after you've fixed this issue of no geometry.
     Now that you do have geometry to be chained, you're chaining "selected" geometry.
     But the problem is, you have no "selected" geometry!
         Dim chains = ChainManager.ChainAllSelected(True)
         'Yyou need to set the geometry entities you're creating as "selected".
               With element
                .Color = 12
                .Level = 2
                .Selected = true ' Added so this entity is makred as "selected".
                .Commit()
            End With
