Genos M460V-5AX help needed.
danielm
I cant explain why my tool path is looking like it is.  This is my first trunion style 5ax.  Its a simple 5ax curve path on an arc segment surface.  I'm starting to think that there is a parameter in the machine thats causing the toolpath to be out.  X 'looks' good.  Y is off negative by maybe .500"  and the tool tip does not follow the curvature of the surface consistently ie its deep and shallow by as much as .050" .  Centerline of A is per factory.  C zero checks out.  My machine def looks correct and I get same result with different posts that are supposed to be proven for this machine.
Can anyone comment on critical 5-ax parameters on this control OSP-P300MA-H that I should look out for....bit settings etc?
Thanks in advance.
DM
Work Coordinate shift process where you touch off the part like a 3 Axis and the machine then takes all the 5 Axis movement that was programmed from that Zero and then adjust the code to run in that new position without it having to be the exact position like it would have to be if you programmed from Center of rotation. The idea is to let the machine do all the heavy thinking so to speak and solve difference in part position to where it really is on the machine.
6 minutes ago, danielm said:
G169 appears to be the equivalent to DFO for this machine.
Manual says:  G169      Tool length offset at cutting edge ON
Doesnt make sense to me....but I turned it off and damn near crashed.
DFO in an Okuma is G605. Not the same thing as TCPC (G169). G605 is used for 3+2 positioning. G169 is used for full five axis cutting. Did you run the 5 axis auto-tune to make sure the rotation centers are set correctly?
5 minutes ago, danielm said:
no.  Please school me on 5 axis auto tune.   I'm looking in the manuals now.....
PM me your email address and I will email you the MU series 5 axis training manual. It gives a more simplified explanation of the auto tuning use than the full manual.
10 hours ago, Mick said:
G605 is DFO? We use CALL OO88 but then, they probably updated since then.
Essentially DFO does the same thing as CALL OO88 but with some differences. As Greg said, CALL OO88 only updates the XYZ offset position so you still need to post the rotary moves. DFO is modal and dynamic. Once G605 is active any rotary move will automatically update the XYZ offset position. The one limitation is that you have to post rotary moves by themselves, no linear on the same line. The biggest advantage and need for developing the DFO was being able to use it in conjunction with slope machining. If you have a casting or other organic part that you need to align the coordinate system to using slope, you can also turn on DFO to maintain that alignment for other rotary positions.
Thanks for the comprehensive explanation Doug. When was G605 made available?
It is a new option that has not been around very long. I just learned of it late last year. I do not know how long they were working on it.
  • 1 year later...
Straight from the horse's mouth:
The conventional fixture offset command (CALL OO88) had to be specified each time the angle of the rotary axis is changed. Dynamic fixture offset function(G605), however, detects the angle change with the rotary axis during function mode ON automatically, executing the process equivalent of the conventional fixture offset command. As a result, the user does not have to execute the fixture offset command upon each time the angle of the rotary axis is changed. -5-AXIS MACHINING FUNCTION MANUAL Section 13
It is OSP-P300 specific.
That error likely means that you don't have everything in the G605 line you need. However, what you are looking to do would be more of a G169 thing. TCPC (G169) is intended to be used for things like 5 axis contouring and 5 axis surfacing. CALL OO88 is used more for positioning to a plane in a 3+2 fashion. (Though I use it before I enable my G169 to preposition my tool to the clearance plane) G605 is for drilling holes around an eccentric shaft. To be honest, it's a lot of work to set up on the code end and CALL OO88 does the same thing EXCEPT you have to kill your drilling cycle, run a new CALL OO88 line, rotate to the new position, then reactivate your drilling cycle on every hole that is at a different rotation. It would be a lot to write by hand, but then again, if you are hand programming a 5 Axis, slap the hand, commend your self for the outstanding achievement, then get a CAM software.
As for autotuning, I attached a file that I made a few months ago that gives a crash course on a bunch of P300 mill features. Though, because I am lazy and because I don't like G605, it isn't mentioned in there.
OSP-300MA QUICK GUIDE.pdf
  • 1 year later...
On 6/20/2018 at 12:08 AM, Greg Williams said:
CALL OO88 does not update the rotary axis positions only the XYZ is updated with this MACRO
Ive just recently dicovered this ( 5 axis newbe with a very cool machine) is there a way to update rotary axis?
