Changing M Codes
OK, here is what I am running into. I have 2 brands of machines, Matsuura's and Mori's. Both are horizontals. Both use an almost identical post. I am working on combining them into one post. I have everything worked out except for the clamp codes on the 4th axis.
The Mori uses M10 & M11. The Matsuura uses M21 & M22
I am capturing the machine description from the machine definition, so the post knows if it is running the Matsuura or the Mori. Is there an easy way to get the post to swap out the M codes?
Yes.
the String Function 'slin' stands for "String List In". It uses an "index variable" (the variable in your "ordered list of numeric and string variables created by MP), and an "offset" from that index variable, to determine "which string variable" we are editing.
There are some decent examples of how to use the function in the documentation.
smtap   : "G84"
smrigid : "G84.2"
# Canned drill cycle string select
sg81    : "G81"      #drill      - no dwell
sg81d   : "G82"      #drill      - with dwell
sg83    : "G83"      #peck drill - no dwell
sg83d   : "G83"      #peck drill - with dwell
sg73    : "G73"      #chip break - no dwell
sg73d   : "G73"      #chip break - with dwell
sg84    : "G84"      #tap        - right hand
sg84d   : "G74"      #tap        - left hand
sg85    : "G85"      #bore #1    - no dwell
sg85d   : "G89"      #bore #1    - with dwell
sg86    : "G86"      #bore #2    - no dwell
sg86d   : "G86"      #bore #2    - with dwell
sgm1    : "G76"      #misc #1    - no dwell
sgm1d   : "G76"      #misc #1    - with dwell
sgm2    : "G81"      #misc #2    - no dwell
sgm2d   : "G82"      #misc #2    - with dwell
sgc9    : "G81"      #custom #9  - no dwell
sgc9d   : "G82"      #custom #9  - with dwell
sgdrill : ""         #Target for string
fstrsel sg81 drlgsel sgdrill 18 -1
# Drilling
pdrill0$         #Pre-process before drill call
      sav_dgcode = gcode$ #Capture gcode for 5 axis drill
      #Set correct Tap Code, based on tapping mode
      if rigid_tap, smrigid = slin(sg81, 6)
      else, smtap = slin(sg81, 6)
Here is a quick sample I whipped up.
The "slin" function uses that "index" variable (1st parameter), as the starting string, in the Variable List.
The 2nd parameter (6), is the "offset" from the 1st string. This is a "zero-based" index, so an offset of "0", means, replace the string that is listed as the "index" variable.
An offset of "1", means replace the next string, 1 space below the index string.
In our case, "sg84" is 6 variables below "sg81".
I could have also used the following to accomplish the same thing:
smrigid = slin (sg84, 0)
Similarly, the function "slout", is used to "retrieve" a string value, from a String Variable, in the ordered list of MP variables.
As an example, if you had enough "temporary string variables" setup in a user-defined (list) array, you could "copy out" all of the string values, in a String Select Table (list), (save them for future use), with "slout". Then you could use "slin" to overwrite all of the existing strings, with new string values. If needed, we could then "restore" all of the original strings, in the string list, using "slin", and writing the "saved" values back to the String Select Table Array.
Awesome Colin! That should work nicely.
As far as why I like to keep things in one post....There are a few reasons. Mainly when updating or adding a new feature I only have to do it once, rather than remembering to do it a few times. And since I've been pretty meticulous about documenting what I've done and the changes I've made, it would be reasonably easy for someone else to follow.
Colin, just a curiosity here.  Can't you identify the machine in the mach def?  Would it be better, worse or indifferent to do something like:
plock
     if mach = mori, "M70", else "M80"
punlock
     if mach = mori, "M71", else "M80"
There are some technical differences. In your example, you are just outputting 'String Literals'. This has the effect of divorcing the output of the codes.
What I mean by that, is you should be using a String Select Function for String output; if that output is a "mode" that you need to track the 'state of'.
The beauty of the String Select Function (and the part that amateur post hackers miss), is the SSF "ties" the string output to the Modality of a Numeric variable?
So what?
Why is that important? Because the magic in the Post is the ability to make decisions based on Boolean Logic.
You can't track a 'M80' String. You can't test it for true/false.
The thing is, if these machine modes were all completely independent, then your method would be just fine.
But by tying the strings to a number, we can now build complex comparisons, to check for multiple conditions.
A good example is High Speed Codes, and Tool Lenth Offsets. Some modes must be turned on before G43, and must remain on until after the G49. Others must be done while TLO is active. We can track the modes through the "current" value of the variable, compared to the "previous" value. Modality is a beautiful thing.
And that is why I asked the master.  I was only thinking in simple lock/unlock codes.  Not as far as any other string value.  Now the "why" here is crystal clear.  You have no idea how much I appreciate the resource you are!
Also, 'yes', we can get the Machine Name string, along with basically anything in the Machine Definition. Each Tool Change event in the NCI File is preceded by 'preparatory NCI line', that set the values of predefined variables before the tool change. We get the machine and information about the Axis Combination. Axis combos don't do much for us, on a 3X, 4X, or even 5X milling machine. But a Multi-turret or multi-spindle lathe is a good example of where the Axis Combos actually provide some value to us.
Just throwing this out there, but If it was me I would not tackle this as a post problem but a machine problem.  I would add M10/M11 to that matsuraas or vice versa.  That way you can use the same exact program for each machine.
If M10 is already taken up then create a new Mcode M110/M111 and Mcode alias it.
I am assuming fanuc control here but, Put 110 in paramter #6021 and make a new program in the library folder O9021
O9021(Universal 4th lock)
M10
M99
etc etc etc.  This way everything is automated and you don't have to keep track of machine descriptions.  But whatever floats your boat.
