Help with 4 axis engraving cannot get post program to work properly
LucasDiaz
I am trying to post an engraving program to my cnc fadal 4 axis, but once the program is on the machines the Axis just rotates too much for what it is supposed to do. Please help!!  This is my first time programming engraving on this machine and previous programmers have gotten the machine to work the 4th axis. Here is the post program being produced thru mastercam 2017. I am using the MPMaster post downloaded from this site. Is the error in the post or the actual mastercam program? Or maybe its user error and I am missing something.  please help!!
O0001 (399885 LETTERING2)
G00 G17 G20 G40 G80 G90
G91 G28 Z0.
(1/32 BALL ENDMILL)
(COMPENSATION TYPE - OFF)
M08
T11 M06 (1/32 BALL ENDMILL)
G00 G17 G90 G54 A75.152 X-.3287 Y0. S5000 M03
G43 H11 Z2.485
Z.485
G94 G01 Z.4825 F10.
X-.3219 A74.534 F1801.95
X-.3158 A73.829 F2078.72
X-.3091 A72.732 F2401.1
X-.3041 A71.517 F2669.87
X-.3011 A70.217 F2862.17
X-.3001 A68.876 F2957.08
A67.81 F2968.69
X-.3015 A66.262 F2952.15
X-.3056 A64.782 F2822.18
X-.3122 A63.436 F2567.97
X-.321 A62.282 F2198.81
X-.3317 A61.372 F1725.05
X-.3449 A60.694 F1174.74
X-.3591 A60.377 F546.93
X-.3735 A60.436 F102.23
X-.3875 A60.868 F745.59
X-.4003 A61.651 F1359.24
X-.4085 A62.427 F1854.01
X-.4154 A63.355 F2224.26
X-.4209 A64.406 F2523.06
X-.4253 A65.685 F2748.85
X-.428 A67.026 F2889.13
X-.4289 A68.401 F2960.34
X-.4282 A70.191
X-.4251 A71.945 F2904.71
X-.4196 A73.614 F2761.22
X-.4117 A75.152 F2536.56
X-.5003 F25.
A60.867 F2968.69
G00 Z2.485
M09
M05
G91 G28 Z0.
G28 Y0. A0.
G90
M30
399885 LETTERING.mcam
1 minute ago, LucasDiaz said:
Can you direct me to the proper forum?
No need to repost, it's already there, the Industrial Forum
Edited by Guest
1 hour ago, Minkash said:
I can see G94 in your program, A G93 is necessary to specify the feed mode on the initial move containing rotary motion. You will need to use Inverse Time, don’t forget to Cancel  G93 with G94 at the end of the rotary moves.
This is only true if you have the Control Definition in Mastercam set to output "Inverse Time Feed Mode".
Most 4th Axis machines are not setup to use Inverse Time Feed Mode. (The control must be purchased with the option, or upgraded onsite, for Inverse Time.)
Most 4th Axis Rotary Tables are setup to use Degrees Per Minute Feed Mode.
The calculation for DPM is:
DPM = Angular departure distance / time required for motion
Time = 3D Motion Distance / Feedrate in IPM
http://www.cnc-academy.com/cnc-programming-articles/programming_feed_rate_in_degrees_per_minute.htm
