5-axis Problem (that is driving me crazy)
Kampfzentrum
OK gents, I got a 5-axis FPT that I'm programming for. When I work with the WCS as the primary offset, the machine works fine. However, when I create additional offsets, this is where the post starts getting funny. Hoping that some of you can help me out... Here's what it does.
As shown in the pic below, I have to face two pads. The position of each pad on the weldment varies, so I've created two different with two different planes; the upper right one is the WCS that I've given work offset number 1, the custom plane below (i.e. Low-East Plane) is offset 2. Now here is where I'm confused.
When I set the data (in the "Planes (WCS)") options menu, I set the custom plane as Top, Low-East Plane, Low-East Plane. The result of this will result in the machine moving to when I have placed the coordinates of Low-East Plane, but then has an additional data shift of the distance from the WCS plane to Low-East Plane. If I go back into the  "Planes (WCS)") options menu and set it to Low-East Plane, Low-East Plane, Low-East Plane; then the head orientates to an orientation that is not what I want.
All I want is to be able to create a custom offset, have it go to the correct coordinates (no additional datum shifts), and have the head orientate to the correct plane.
Help!
On ‎8‎/‎20‎/‎2018 at 2:43 PM, lowcountrycamo said:
Do your top plane and low east plane originate from the same point?
Thanks for the responses guys, sorry for the late response, I was out sick (it's going around).
As for the Low-East Plane, as you can see, it does appear to originate from the WCS plane, but as soon as I zero ("0") these out, the plane will relocate to the WCS plane. So how to zero these out without moving the custom plane to the WCS plane?
On ‎8‎/‎24‎/‎2018 at 8:58 AM, David Colin said:
May you share a file?
3 hours ago, David Colin said:
I guess you have a post issue or needs info/training to know how to set Mastercam toolpaths to make your post work. You should ask your post seller.
I believe I found it, went into the post and found the line:
ignoreorg             :  1              #Ignore toolplane origin, use WCS origin (0=off, 1=on)
It was on "0", I changed it to "1", post seems to be good now, I need to verify with the operator.
  • Huh? 1
