Parallel 3x error string select is out of range 11
I modified a generic post for Okuma 3x.  Been running for some time but when I use Parallel and output 3x I get this error:
pst 694 - the value of the string select selection variable is out of range: 11
pst 715 - the value of the string select selection variable is out of range: 11
I have look for some time and cannot find my error.
steve
OKUMA 3X 650.pst
Right off the bat I'm seeing that both problem lines are using sgcode string variables so I would look at that string select table first. What version of Mastercam did this post originate from? You might need to get the latest version of MPMaster and compare the string select tables for that variable to see if yours needs to be updated. I had the same problem with some of my posts, except it was just for the newer High Speed surface toolpaths, so nothing that would wreck the post, but it was annoying to see them all the time.
Range = 11 is the prime clue.
5X motion is output as "NCI GCODE 11", which is just point-to-point Vector Moves. The post usually detects this, and sets 'gcode$' back to '1', prior to output. Or, there is somewhere where 'gcode$' is being changed.
The 'sgcode' String Select, uses the Numeric Variable 'gcode$' to control the modal output of motion Gcodes.
Collin, it did get rid of the error but did not post past the tool change.  I am unsing mcam 2018.  This program uses the parallel utility transform rotation if that helps.
Thanks guys,
Steve
O0000(1159LM41008-11 OP 1 AND 2)
(31-08-18 - 06:18)
( T13 | 3/8 BALL ENDMILL FINISH TOOL  .875LOC 1.CLR | H13 )
G17 G40 G80 G90 G15 H01
( FINISH CORNER RADIUS )
N13 T13 M6
( 3/8 BALL ENDMILL FINISH TOOL  .875LOC 1.CLR | TOOL - 13 | DIA. OFF. - 13 | LEN. - 13 | TOOL DIA. - .375 )
G0 G90 X-.863 Y.6614 S5800 M3
G56 H13 Z1. M8
M5
M9
G00 G90 Z20.
M30
Looks like the 3X Posts might be missing some code to properly process 5X output (in a 3X environment).
Try adding this Post Block (it isn't in your current post), below the 'pmx$' Post Block:
#Pre-process rotary motion control flags
pmx0$            #5 axis gcode setup
      if drillcur$ = zero,
        if fr$ = -2, gcode$= zero
        else, gcode$ = one
