Help with D## output
I have modified my Okuma post logic to output G56 HA if tlngno$ = 10001 | tlngno$ = t$. Further more it will output G56 HB if tlngno$ = 10002 and G56 HC if tlngno$ = 10003. Here is the code
ptlen           #Tool length offset
        if tlngno$ = 10001 | tlngno$ = 10002 | tlngno$ = 10003 | tlngno$ = t$,
           if tlngno$ = 10001 | tlngno$ = t$, *sg56, "HA"
           if tlngno$ = 10002, *sg56, "HB"
           if tlngno$ = 10003, *sg56, "HC"
        else, *sg56, *tlngno$
        !tlngno$
However, I cannot for the life of me get it to work the same for the cutter comp without getting the output on every line
pccdia          #Cutter Compensation
      #Force Dxx#
      if prv_cc_pos$ <> cc_pos$ & cc_pos$, prv_tloffno$ = c9k
      sccomp
      #if cc_pos$, tloffno$
      if cc_pos$, ptoff
ptoff           #Tool radial offset
        if tloffno$ = 10001 | tloffno$ = 10002 | tloffno$ = 10003 | tloffno$ = t$,
           if tloffno$ = 10001 | tloffno$ = t$, "DA"
           if tloffno$ = 10002, "DB"
           if tloffno$ = 10003, "DC"
        else, *tloffno$
        !tloffno$
Here is the posted code:
N1 ( 1/2 FLAT ENDMILL )
G90 G17 G80 G40 G00
G30 P10
G116 T1
G15 H2
G131 F1260. J1 E.002
G00 G94 G90 X-2.4 Y-.1
S5000 M03 T2
G56 HA Z1. M08
G01 Z-1. F30.
G41 DA X-2.35
G03 DA X-2.25 Y0. I0. J.1
G01 DA Y1.5
G02 DA X-2. Y1.75 I.25 J0.
G01 DA X2.
G02 DA X2.25 Y1.5 I0. J-.25
G01 DA Y-1.5
G02 DA X2. Y-1.75 I-.25 J0.
G01 DA X-2.
G02 DA X-2.25 Y-1.5 I0. J.25
G01 DA Y0.
G03 DA X-2.35 Y.1 I-.1 J0.
G01 G40 X-2.4
G00 Z1.
G130
G00 Y-.1
G01 Z-1.
G41 DB X-2.35
G03 DB X-2.25 Y0. I0. J.1
G01 DB Y1.5
G02 DB X-2. Y1.75 I.25 J0.
G01 DB X2.
G02 DB X2.25 Y1.5 I0. J-.25
G01 DB Y-1.5
G02 DB X2. Y-1.75 I-.25 J0.
G01 DB X-2.
G02 DB X-2.25 Y-1.5 I0. J.25
G01 DB Y0.
G03 DB X-2.35 Y.1 I-.1 J0.
G01 G40 X-2.4
G00 Z1.
M09
M05
G130
G30 P30
M01
N2 ( 1/8 DRILL )
G90 G17 G80 G40 G00
G30 P10
G116 T2
G15 H2
G00 G94 G90 X0. Y0.
S6000 M03 T1
G56 HA Z1. M51
G71 Z1.
G81 Z-1. R.1 F25. M53
G00
M09
M05
G30 P30
M02
What am I missing? If I do not use the ptoff logic and use the if cc_pos$, tloffno$ line in the pccdia post block it works as expected and only outputs on a single line with the numerical value. I know it is something simple that I am overlooking.
Thank you in advance.
Brad
6 hours ago, jeff.D said:
In MP strings are non modal so the literal string will always be output.  This also applies to strings that are in a variable, for example sg56.  Adding the force leader (*) to sg56 is redundant, it will always be output.
Strings that require modality are usually set up in a string select table.
I understand that the *sg56 is redundant I just like to see it so I know it is forced without question. As for the D value if I use if
      #Force Dxx#
      sccomp
The D## only appears at the G41 line as a numerical value. But when I change that block to
      #Force Dxx#
      sccomp
      if cc_pos$, ptoff
It puts the D## value on every line, although in the correct format that I'm looking for; DA, DB, DC or a numerical value. I just want to get rid of the redundant D## values, the G56 H## logic works perfect.
Try setting them up in a string select table, like below.
tool_rad : 0
sDA       : "DA"
sDB       : "DB"
sDC       : "DC"
stool_rad : ""         #Target string
fstrsel sDA tool_rad stool_rad 3 -1
The change your ptoff post block to the below.
           if tloffno$ = 10001 | tloffno$ = t$, tool_rad = 0
           if tloffno$ = 10002, tool_rad = 1
           if tloffno$ = 10003, tool_rad = 2
           stool_rad
           if op_id$ <> prv_op_id$, result = force(tool_rad, tool_rad)
        else, *tloffno$
        !tloffno$
You'll also have to add the force line (shown below) to the psof$ postblock
