Current toolpath is not for 4-axis machine
By
SlaveCam, in Industrial Forum
SlaveCam 104
Now its gone. Go figure.
Mark VIII 44
I was getting the same thing, except mine said 3-axis. I was like, duh, it's a 4 axis program.
ahaslam 40
Now I'm getting it. Were your programs originally 2018 updated to 2019? I'm not really sure what is going on with this.
Did anyone ever figure out anything with this? Seeing the same issue after migrating from 2017 to 2020
5th Axis CGI 4,252
Check your machine defined in the simulation side in the Verify. That might be what is creating the issue.
JoshC 236
Did you use the Transform into WCS check box in mach sim settings? If a plane other than top is used you need to be usign transform into wcs check box. And the top plane must be table view, or use a WCS that represents a table view instead of top plane and use transform into wcs, its a check box in mach sim settings.
1
On 11/7/2019 at 6:59 PM, 5th Axis CGI said:Check your machine defined in the simulation side in the Verify. That might be what is creating the issue.
On 11/8/2019 at 8:59 AM, JoshC said:Did you use the Transform into WCS check box in mach sim settings? If a plane other than top is used you need to be usign transform into wcs check box. And the top plane must be table view, or use a WCS that represents a table view instead of top plane and use transform into wcs, its a check box in mach sim settings.
I did both of these, and still have the same warning. Strangely, the verification carries on perfectly fine anyways.
1
Recently Browsing 0 members
Why is Mastercam giving me this "error" when trying to verify a simple NCI transform (translate) operation? I can simulate it, but this message comes up everytime stealing the focus, thus annoying the heck out of me.
