dynamic optirough setting cut depths
DCOPE17
So I'm roughing out a large pocket, Highspeed toolpath with small stepover and deep cut. I want to rough 1.9" deep then, because I have 2" flute length, make another operation to cut to the remaining 3.8" deep. Figured I'd copy the operations and on the first, I'd draw a surface at 1.9 and add it to the geometry so that op would only go 1.9 deep. Then adding more to the wall and floor stock for the remaining depth to keep from rubbing the shank.
Problem is, how do I start this operation 1.9" deep?
I'm used to the older Mcam where I can set min and max cut depth so I can control when the pocketing starts and stops both the top and bottom.
Any help again is greatly appreciated. .
Dan
You can still set min/max, although I haven't used the older Mcam. I believe what you're looking for is under steep/shallow. Check "Use Z depths" then the options become available.
Rereading your post. You don't actually have to draw additional geo with this setting. You just set the height you want in the steep/shallow
