2D Dynamic not cleaning floor
DavidB
14 hours ago, DavidB said:
I believe there is bug in MC when using an endmill with a corner chamfer.
If I just change the toolpath to use a square endmill it cleans the floor. If I use a an endmill with a 0.5 chamfer corner the floor does not clean up.
What if you tell Mastercam that the end mill has a corner radius instead of a chamfer? Does it clean up then?
Or can you tweak the Toolpath Radius (not the stepover) a little bit?
Reply from QC
Hi David,
Thank you for contacting us with your findings with 2D Dynamic and using a Chamfer mill.
This is now logged as R-18085 with your information so the developers can take a look.
A possible work around is to still use your Chamfer mill but label it as a radius tool with a .8 radius when programing. This is giving a clean floor. I did test this back to X7 and it appears this problem has been with us since then and maybe before then.
Regards,
Curt
