Cam62
Feed change during Finish Toolpath
Is it possible in Mastercam 2017 (Lathe Toolpath) to change feed rate for the last final pass on a Finish tool pass or do you need to manually edit the NC post file or run/chain another finish pass?
Example: 5 final passes, removing .010" each at feed rate of .003/rpm and want final 5th pass at .001"/rpm in order to achieve adequate surface finish.
Cam62
You can use toolpath editor.
I would create 2 finish ops, for the ability to regenerate.
1st Op - leave. 005 stock.
2nd Op - final finish pass.
The Toolpath Editor is a great tool, especially when you are in a hurry. But the changes are made manually, and it locks the operation after you make the edits.
You can use semi finish in the roughing op. This will allow you to change the feed rate for the "finish" pass in the roughing op.
Another great option.
