mike561h
Mastercam 2018 -3 updates still wont open sld.prt
 i have no problem converting solidworks/ sld.prt in Mastercam on my seat.   We downloaded and installed 3 updates for MC18 on
My coworkers seat on  different computer.....,, opens up  nothing after converting....... Not even an error message.   Nothing shows up on the screen.
weird... Halloween is over.😡
  • Huh? 1
emailed trevor and he thinks its the video card. but  its the same card  in my computer and i have no problems. any help will be appreciated.
Are you 100% sure that the computer with the issue is set to launch Mastercam with the Graphics Card???
Most systems will default to "Onboard graphics", which means that Mastercam launches without ever using your high-end card.
Right-Click on Desktop, and go to NVIDIA Control Panel (assuming you have an NVIDIA card?), and go to "Manage 3D Settings".
Under the "Global Presets", select a Profile for either Catia or Solidworks. (Dassualt Systems - CATIA Compatible). And set the preferred processor to "Higg-performance NVidia Processor".
Then, go to the 2nd Tab "Program Settings", and choose the "Add" button, then "Browse".
Navigate to:
C:\Program Files\Mcam2019
and select "Mastercam.exe".
Make sure it is set to "High-performance Nvidia".
Do the same process with:
C:\Program Files\Mcam2019\Extensions\CodeExpert.exe
and
C:\Program Files\Mcam2019\Extensions\ToolManager.exe
Make sure all three programs are set to use the Nvidia card...
Also, I have seen weird stuff from Mastercam, if the following permissions are not set:
C:\Program Files\Mcam2019     <---   Set this Folder to "Full Control" for the active user profile.
C:\Users\Public\Public Documents\Shared Mcam2019    <--- Full Control
C:\Users\<Your User Path>\My Mcam2019    <--- Full Control
Navigate to:
and
ill check it out thanks.
I don't see anywhere to select the preferred processor.
Just now, 5th Axis CGI said:
I got that. I don't see where the And set the preferred processor to "Higg-performance NVidia Processor" is.
Not sure what he means with that wording, but what I showed you is all I am aware you can do in the Global Settings.
I also don't see where this " Make sure it is set to "High-performance Nvidia". , is set. :unsure:
I think you are talking about how to make sure that the computer is using the dedicated Video card being the Nvidia GPU and not the onboard.
we have under our "Knowledge Base Articles" page a article that covers this topic.
Link to article: https://kb.mastercam.com/KnowledgebaseArticle50338.aspx?Keywords=enable+graphics
I went into the BIOS and disabled the onboard video card so I don't have to choose which one.
What version of SW did the SLDPRTs come from?
You're running MC2018 update 3 ... there's no support for SW 2019 SLDPRTs until MC2019 Update 3.
i was able to open the part file i was sent with no issues. mike, this has to be the graphics settings. email me your number. i will be working in north county today and may have time to stop by.
mike...i tried to email mr. galey but his email bounced back. make sure that one of you guys sends me a direct phone number. ill do my best to get over there sometime close to noon, if not before.
You need to talk to your salesman and tell him what you need.  When I had 2018, in my previous job, they sent a tech and he did some tingamajig  on the command line and then I could open SW files.
sent you a email with phone
The video card is AMD Radeon HD 8570 Graphics card. I have the same in my station and I have no problems with
converting Solids works 2018 sldprt  file into MC18
thanks,
we upgraded to solidworks 2018  last year
I believe only MC2018 Update 3 supports importing of files from SW 2018. Please check that your co-worker is up to Update 3.
If he/she is, then it might be this sepatrate problem...
There is a .DLL that both SW and MC use that sometimes get in conflict with the versions of MC and SW being run.
Use the process to re-register the dll for Mastercam...
  • Shutdown Mastercam go into Windows Start Button > Mastercam 2018 > Advanced Configuration > Click on Componenets
  • Navigate to...C:\Program Files\mcam2018\common\SWORKSDATA
  • Right-click on SWDocumentMgr.DLL and choose "Register"
Then restart MC and try again to open the SLDPRTs.
There are other posts on this forum which point you in that direction.
  • Haha 1
Trevor fixed it in house... All is good. Great Job!!!   Its above my Taco Tech level...
