So not a Guru
Odd threadmill action in 2018
This might just be how it works, but I seem to remember doing this in earlier versions differently.
I have a threadmill with 1/8" of flute lenght and 7/8" of extended reach, and I'm threading .40" of depth.
The path is broken into 3 separate vertical sections, instead of screwing all the way from bottom to top. Am I missing something in my settings?
I've attached a pic showing what I'm getting on the left. Ignore the paths to the right, they're made by the full length threadmill that hasn't gotten to our facility yet:rant:1459951730_THREADMILLISSUE.thumb.PNG.c4f6d8134abb275941cd08ebc1964712.PNG
Tell it the tool has one tooth in the operation and it will machine from bottom to top.
Thanks Ron, I knew I made it work correctly before. I've slept at least twice since then, so my oldtimers wipes that memory away. 🤪
I don't remember what but I have two R-#s on threadmill in 2018.  One was the displayed toolpath is incorrect but posted correctly.  That may be what you're seeing there as it is similar to what I recall.  The other was on migrated files not having the second checkbox for end at center (maybe that one is 2019).
I occasionally still see improper display on threadmill and post to check the code.
That wasn't the case here, the code output exactly what the display showed. I think it may have always been like this.
yeah buddy, lie to it and tell it one tooth. I also always drive it off a point rather than an arc. Dont know why, guess I just like to define my major diameter, just how I do it... I hardly ever use a tap anymore.... Crappy thing is sometimes you change something and it defaults back to 3 teeth...err always back plot a thread mill before posting..
That right there.  I ALWAYS check my threadmills in cimco backplot before taking it out or putting it on the server.
Yes, this is what it's supposed to be doing.
The cut pattern page reads the tool data to determine how many threads are active, which is defined by the thread pitch and cut depth:
 image.png.ead96449f051ab3572fc46930b87cc17.png = image.png.9346c6d20ce65536b7fe6bb0846d7ee4.png
If you change tools or even click on your tool again, it will reinitialize that Cut Parameter page setting.
If you never take advantage of using a multi-point threadmill, I would suggest that you define your tool with the cutting length set to one tooth (in my example above, that would be .05 or 1/20).
Check out 2020 then:
I have always wanted the ability to lock the active teeth setting or disassociate it from the tools cut length
I've had cases where editing the tool's feed rate, rpm or tool number has reinitialized
that setting and resulted in a bad toothpath
Just reselecting the tool will reinitialize this setting as well.
In So Not a Guru's example the only way to ensure this doesn't happen it to lie
when building the tool and define the tool as a single point thread mill even though it's real
length of cut is 3P
This has burned me dozens of times. I usually catch it before posting, but it has really bit me more than once
Nice!
length of cut is 3P
Yeah, it's the classic "I want it to be smart enough to look at the tool!"  "I don't want it to look at the tool anymore!"  dichotomy that we always seem to run into.
In ideal-land, we would always be able to instance darn near everything from the tool & material information.  In reality-land, there's plenty of places where you want to override it.
The problem that we have in an instance like this is we can detect if you've changed it and never change it again, but what happens when you select a completely different tool.  Would you have wanted it to update in that case?  Yeah, probably.  What about in the case where you've saved it with a value, but you're importing the toolpath and re-selecting geometry and tool?    Etc., etc., etc..   So to be predictable, if you reinitialize the tool at all (re-selecting it, changing parameters, etc.), then update the settings.
It's one of those fun no-win scenarios :)
This is one of those moments when the best enhancement would likely best be a warning that tells you that you have just changed following parameters as a result of clicking the tool, or make it a setting that we can change based on preference.  But certainly a no win situation as we all have different schools of thought on the subject.
