Reduce cusping & faceting during mill contouring of a cylindrical surfaces
I work in a small Tool & Die shop equipped with a Hurco Ultimax 3 & a new Haas Super Mill 2.  We are still using MC X2.
The problem I had was on the last job on the Haas, milling a round part. First thought anyone has... cylindrical ---cut on lathe? Sadly, I  could not. It was a cylindrical groove ( 3.610" I.D./3.922" O.D. x .562" dp.) that made the seal edge of the final molded part. I used a Toolpath-Surface finish with a 3/32" ball end and took cuts with a.001" step over  and I used "total tolerance" of 0.00005".
This resulted with around the bottom angled surface it was faceted like a diamond (at 90 degree points). The at 0 & 180 degree positions on the circle the cutter was making moves of .015/.022 in "x" & .0001/.0015 in "y".  At 90 & 270 degrees  .0001/.0015 in "x" & .015/.022 in "y".
This leaves large cusps & faceting at 4 positions at the bottom angled surface of the seal groove. I have changed all the settings to eliminate/reduce the faceting, but the only way to get the x,y moves smaller is to use a smaller diameter cutter.
What Toolpath/ Settings should I use? Am I using the wrong Toolpath?
Any advice about a possible work around (other than a MC upgrade) would would be grateful.
I will have someone check for possible backlash.
We purchased the Haas new this last year. I have run numerous programs on this machine. This is the only program / Cad that this machine has this problem with.
 It maybe from the hardness of the steel (46/50 R/C), cutter size, feed, & the depth of cut, causing the cutter(s) to flex when it does a .015"/.022" move.
I have tried different settings to reduce the .015/.022 move,but I have been unsuccessful in reducing it.
If at first you don't succeed.... so much for Skydiving!
I could not get a screenshot of the "Filter setting" (not present in MCX2). I have attached a zip file of the MCX  & posted NC files.
I am trying the Surface Finish-Scallop. I did not use it before before because it took a long time to do processing. If the settings are to tight , my computer will lock-up MC & crash .
So far it has been 45 minutes. Hopefully, it will not error.
CAVITY_BLOCK.zip
.00005 for a total tolerance?
That's waaay too tight. You should loosen it up and filter to try to create arcs especially for a machine such as haas. As little point to point moves as possible. Backplot will give you a great idea on the smoothness of the toolpath (turn "display endpoints" on)
I have success! It was a combination of errors on my behalf. I changed to a "Constant Scallop" and I reset the "total tolerance", set starting point to the center of the outside diameter of the groove , turned on the filter ratio, set it to 1:3, & used 1.8 min r. & 1.97 max r.
It returned a radius cut instead of linear moves. Smoothing out my passes.
I would like to Thank everyone for your help.
