master80
EDM 4 TH AXIS
should work but you'll need to break it up so you have the same # of segments top and bottom
can  you please show me on this part what you mean
Can you save the file as something else. All I have is MCX7
STP FILE ???
Just now, master80 said:
STP FILE ???
that will work
can't right now, ill try later
thanks
You don't have your sinking matched correctly. With wire you must think about your break points in your chains for the cut you are doing. I remember Sodiek programming at the machine and for shapes like this I would do like you are doing and make a top shape and a bottom shape. I would then tell the control to sync certain points and it would do all the work for me. In Mastercam you need to think the same way since you want the shape cut a certain way you need to make your entities or control points match that. We do the same thing in 5 axis programming. You not finishing out the top shape for the cut and forcing the system to control the bottom cut with the little arc and line. Draw a straight line from each and mentally use that as your process to think about how is the wire going to cut it. Your top shape doesn't lead off the part it stops short, but you want the wire to complete the cut. You need to think about approaching this differently. There are many different stesp to explain so hopefully my levels and names on the levels help to show you a way to go about doing this.
Here is one way to go about it and hopefully it helps give you an idea how to approach it.
EDM Example
10-1245-134-ins WIRE 4 TH AXIS OLD VER.step
I just split the solid at z.75 and z1.5 and extended the top to to clear the part. As long as you set your planes right on the wire the shape is the same. I created branch points and thats how you should sync it.
Its hard for me to go back and use MCWire after using Esprit. Messes with my head. In Esprit all I do is select those faces and wire path it.
can you send me some video sometime ???
Del, I didn't try that as a process I was just taking his work and showing him how to use what he was doing. I am a hack when it comes to Mastercam wire, but I don't see a solid face selection process so have to assume not possible.
ok guys ,I try run this on my wire machine .We have Sharmilles  Robofil 690 and show me alarm  " taper uv  mode is not compatible with the program "There is same sething on the control activate this thing ??
this is mu codes
O99
( DET )
( 4 AXIS PROGRAM )
N1 G90
N2 G92 X-3.3171 Y1.07055 I2.28684 J.26884
N3 M60
N4 G41 G01 X-3.17518 Y.87004 Z.26884 U.17472 V-.57472
N5 X-2.21736 U.57472
N6 X-2.20581 Y.86964 U.57484 V-.57473
N7 X-2.19423 Y.86842 U.5749 V-.57474
N8 X-2.18267 Y.86639 U.57485
N9 X-2.17119 Y.86356 U.57473 V-.57472
N10 X-2.15985 Y.85994 U.57453 V-.57465
N11 X-2.14871 Y.85553 U.57428 V-.57452
N12 X-2.13783 Y.85037 U.57398 V-.57434
N13 X-2.12726 Y.84448 U.57366 V-.57409
N14 X-2.11708 Y.83789 U.57335 V-.57377
N15 X-2.10732 Y.83063 U.57304 V-.5734
N16 X-2.09805 Y.82274 U.57278 V-.57297
N17 X-2.09148 Y.81649 U.57471 V-.57472
N18 X-1.41337 Y.13837 U0. V0.
N19 X-1.40313 Y.12844 U.00369 V-.00343
N20 X-1.39259 Y.11881 U.00766 V-.00662
N21 X-1.38177 Y.10951 U.00052 V-.00041
N22 X-1.37067 Y.10054 U-.00135 V.0011
N23 X-1.3593 Y.09191 U.00282 V-.00202
N24 X-1.34768 Y.08363 U.00447 V-.00301
N25 X-1.33581 Y.0757 U.00256 V-.00161
N26 X-1.32371 Y.06813 U.00055 V-.0003
N27 X-1.31139 Y.06093 U-.00156 V.00092
N28 X-1.29885 Y.05411 U-.00377 V.00202
N29 X-1.28612 Y.04767 U-.00605 V.00302
N30 X-1.2732 Y.04162 U-.00147 V.00067
N31 X-1.26009 Y.03596 U-.00002 V.00001
N32 X-1.24682 Y.0307 U-.00236 V.0009
N33 X-1.23341 Y.02584 U.00246 V-.00083
N34 X-1.21985 Y.02138 U.00418 V-.00126
N35 X-1.20616 Y.01735 U.00191 V-.00051
N36 X-1.19236 Y.01372 U-.00036 V.00012
N37 X-1.17845 Y.01052 U-.00268 V.00061
N38 X-1.16445 Y.00774 U-.00506 V.00098
N39 X-1.15038 Y.00537 U-.00747 V.00123
N40 X-1.13624 Y.00344 U-.00234 V.00031
N41 X-1.12205 Y.00193 U-.0006 V.00008
N42 X-1.10782 Y.00086 U-.00404 V.00027
N43 X-1.09356 Y.00021 U.00112 V-.00003
N44 X-1.0793 Y0. U0. V0.
N45 X.08425 U.027
N46 G40 Y.24565 U0. V0.
N47 M50
N48 G00 X-3.3171 Y1.07055
N49 M30
I don't know if Mastercam wire has this or not. It saves time from creating wireframes if the solid is accurate.
this is mu codes
O99
( DET )
( 4 AXIS PROGRAM )
N1 G90
N3 M60
N45 X.08425 U.027
N47 M50
N49 M30
I cant say for certain but maybe the taper is too steep maybe?
How much stroke does the machine have to cut this. I am thinking you may need to tilt the part to allow the motion to work. Look at how much travel you have to do this if that motion is greater than that you might get this alarm was my thinking when I 1st looked at the file.
