getting point coordinate with vbscript
Hello All
I'm trying to write a vbscript that will ask for a point and then return the values. I have been trying on my own with very little success.
I'm a bit confused with the GetPointData (EntityEptr as Integer,  Point as McPt) As Boolean
If anyone could point me in the right direction and possibly with a example script, it would be much appreciated.
Thanks, HollisT
' Ask the user to select a point position
' -- Start Script
Call Main()
'Call OtherAskPoint()
' Sub Declaration
Sub Main()
Dim objPoint
Dim strX, strY, strZ
Set objPoint = New McPt
' Prompt for a point location and fill a McPt with the result
If askPoint(objPoint) Then
    ' Show the user some properties of this point
    With objPoint
      strX = "X = " & FormatNumber(.X, 4, -1)
      strY = "Y = " & FormatNumber(.Y, 4, -1)
      strZ = "Z = " & FormatNumber(.Z, 4, -1)
    End With
    ShowString PointPickType & vbCrLf & "Point Coordinates" & vbCrLf & strX & vbCrLf & strY & vbCrLf & strZ
Else
    Call ShowString("No point selected")
End If
Set objPoint = Nothing
End Sub
' Another method of asking for a point position
Sub OtherAskPoint()
if AskForPoint () Then
    strX = "X = " & FormatNumber(GetPoint(0), 4, -1)
    strY = "Y = " & FormatNumber(GetPoint(1), 4, -1)
    strZ = "Z = " & FormatNumber(GetPoint(2), 4, -1)
Else
End If
End Sub
' Retrieve the point pick type "description"
Function PointPickType ()
    Dim str
    Dim ptType
    ptType = GetPointType ()
    Select Case ptType
        Case "1"
            str = "EndPoint #1"
        Case "3"
            str = "EndPoint #2"
        Case "C"
            str = "Center"
        Case "I"
            str = "Intersection"
        Case "K"
            str = "Sketch"
        Case "M"
            str = "MidPoint"
        Case "O"
            str = "Origin"
        Case "P"
            str = "Point"
        Case "U"
            str = "Quadrant"
        Case Else
            str = "UnKNown"
        End Select
    PointPickType = "*" & str & "*" ' returned
End Function
