Sign in to follow this
pullo
Has anybody else set up a 5 ax post for the new DMU-60 EVO
I have right now ascertained , that I have to use a shift of "circa" -150 degs on the C-axis for the machining to look "right" ,  so that is the ballpark , but  what is the  precise value, ?
Gracjan
So ,  in order for a post to work properly for this machine ,these  vectors have to be input :
1. The vector of the spindle 0,0,1
2. The vector of the variable rot. axis (C) 0,0,1
3. For my machine ( these values will slightly differ from machine to machine  )  0.5849.... , -.5735..., 0.5735...
   which is 44.6 degs from TOP and 44.6  degs from FRONT
with these values I tried to machine the chamfer on the part , the axis of the tool pointing towards the center
and this is what I got  ( a totally senseless result)
After manually trying out  a few values , I came to the conclusion that a Shift in  the C-axis of -150 was more or less what I am looking for  (this value
of -150 gets added to every C axis output.
With the shiftc of 150 in my post , this is what I saw on the machine :
I just realized that the heading is WRONG IT SHOULD BE DMU 60  EVO
well anyways back to the subject...
and this is the result on the machine , or in laymen terms , all is fine.
the axis of the tool intersects the axis of the cental hole of the part , etc.....
Gracjan
Seems like gcode is responsible for the 670 evo :) . It is , I say again DMU 60  evo.
Gracjan
Gracjan
Yes I have webby powers that were unknown to me
I fat fingered the title to this thread while trying to copy /paste it for a google search :rolleyes:
I am not a Heidenhain guy but they must be a way to move the C axis machine zero point?
  • Sad 1
how you figure he's got a HH control?
 Maybe if he can post up his toolpath code we can figure what he is talking about.
Plane Spatial /CYCLE 19 or M128 for the HH 5ax stuff.
SAUSAGE FINGERS!
4 minutes ago, Newbeeee™ said:
SAUSAGE FINGERS!
THAT's WHAT S.........
nevermind
  • Haha 2
I'm still over here wondering what he's talking about.  He's running vector code but offsetting 150°?
I googled that machine and it looks like a plain old trunnion machine to me.
I'm lost and over here polishing my bowling bat hoping he can slam dunk a touchdown.  😕
Posted (edited)
So many answers I have to give here.... :) Actually , I was hoping to get an answer from my esteemed colleagues  :)
Greg Williams :  "this value of -150 gets added to every C axis output." .  This is the definition of  a shift .  We are of course talking of a rotary shift.  If you mean that I could get the shift done on the control , yes I could do that probably with a Cycle Def 7.0 Datum Shift , C-150 command . The result would be the same. However , if for some reason the
operator would negate the command we'd get a crash...
mkd : yes it is a Heidenhain  control on this machine.  I was referring to machining when RTCP is turned on (M128).  The  plane spatial/Cycle 19 works fine ,  as I can sidestep the issue of outputting  the B-angle by outputting the A and C  angles.  The machine will calculate the right B angle based on A .
JLW:  I will slam dunk this probably today.  I will measure  the position of a hole on the outer axis of the the table ( for max angular precision)  in 3-axis mode and the I will position a gauge above the hole in RTCP /M128 /5-axis mode and see if the positions aline .  I realize this is a reverse engineering approach, but it's one that will get me close
to the end result and that will give me time to ask around/figure it out , whilst the customer is chugging away on his new DMU-60  evo:)
Edited by pullo
spelling etc
Seems odd that you need to add 150 to the C axis, somewhere in there you will be able to set the zero position.
What post are you using?
Could always say p_out = p_out+150?
So , did not get an answer here ,  I will have to continue my snooping work the next time a 5-axis (M128) case comes around . ....
Gracjan
So it turned out that my C-150 was just one special solution for one problem , but it would not have worked in general.  It turned out that by tweaking two parameters
in  my Camaix post I was able to output the right angles  without the C shift .
Gracjan
  • Sad 1
jlw , wanted more info about setting up the post , so here it goes :
it's a table - table  , with  the B-axis vector always provided by DMG  as in the picture:1257296850_IMG_20190206_0935451.thumb.jpg.fd96eef25df2ea3940c3145831a9da7d.jpg
other than that , nothing special about setting up a post for it .
Gracjan
Might throw that out there next time also. They do it completely different than just about anyone. B)
  • Haha 1
dP
Edited by 5th Axis CGI
Double Post no reason to repeat myself.
Just a thought....you can set your post, to give you in M128 mode(5x) the surface-normal vectors NX, NY, NZ, instead of your machine axes. Same code will work in a machine with a different kinematic also.
  • Haha 1
I don't think you need to use LN to support different axis combos; AC code in M128 will run on an BC machine.
I think you mean TX, TY, and TZ for the tool vector.
