Custom Drill Cycle won't output R value for additional points
I'm using the custom drill cycle to create a double fine boring cycle.
When there is only one hole, it works fine, but when there are additional holes, it doesn't post out the retract value.
for one hole, It uses the postblock pdrlcst$ and outputs the retract value through the postblock prdrlout
for the additional hole, it uses the postblock pdrlcst_2$, and even though I have the postblock prdrlout, it won't read it
Looking to get the R value in all lines that have the G76
Here is the section of the post
pdrlcst$         #Custom drill cycles 8 - 19 (user option)
      #Use this postblock to customize drilling cycles 8 - 19
      pdrlcommonb
      pcan1, pbld, n$, "G76", pfxout, pfyout, pfzout, pcout,*prdrlout, *shftdrl$, dwell$, *feed, *sgdrlref, strcantext, e$
      pcom_movea
      pbld, n$, "G00", e$
      pdrlcommonb
      pcom_movea
pdrlcst_2$       #Custom drill cycles 8 - 19, additional points (user option)
      pdrlcommonb
      pcom_movea
      pbld, n$, "G00", e$
      pdrlcommonb
      pcom_movea
Thanks Jeff! That makes sense.
Do you know which variables on which to put the (*)?
prdrlout        #R drill position
      if cuttype = one, refht_a = refht$ + (rotdia$ / two)
      else, refht_a = refht$
      refht_i = refht$ - initht$
      if cuttype = three, refht_a = w$
      if absinc$ = zero, refht_a, !refht_i
      else, refht_i, !refht_a
This is the code that is posted.
O0001(TWO DRILL CYCLES.NC)
( DOUBLE BORE CYCLE TEST )
(OKUMA)
(NOT PROVEN)
( 04 / 08 / 19 )
(PROGRAMMED TO CENTER LINE OF CUTTER)
N10 G20
N20 G90 G80 G40 G94 G17 G0
N30 N7 G116 T7
G15 H01
( .249 REAMER  HOLE .249/.2498   TOOL - 7  DIA. OFF. - 7  LEN. - 7  DIA. - .249 )
N40 G0 G90 X0. Y0.
N50 S1069 M3
N60 G56 H7 Z1. M8
N70 G71 Z1.
N80 G76 X0. Y0. Z-1. R.1 Q5. F6.4 M53
N90 G00
N100 G71 Z1.
N110 G76 X0. Y0. Z-1. R.1 Q5. F6.4 M53
N120 G76 X2.2417 Y.7523 Z-1. Q5. F6.4 M53
N130 G00
N140 G76 X2.2417 Y.7523 Z-1. Q5. F6.4 M53
N150 G00
N160 M5
N170 M9
N180 G0 G90 Z20.
N190 G0 G90 Y20.
N200 M30
N210 %
Thanks Jeff. That worked. Here is the postblock and the added forced variables if someone else has this problem.
      if cuttype = one, *refht_a = refht$ + (rotdia$ / two)
      else, *refht_a = refht$
      *refht_i = refht$ - initht$
      if cuttype = three, *refht_a = w$
      if absinc$ = zero, *refht_a, !refht_i
      else, *refht_i, !refht_a
