Sign in to follow this
SlaveCam
Getting transform op's work offset number
Why is this not working?  All I get is -99999, also test = opinfo(15332, 0) will yield the same result.
     if op_id$ <> xform_op_id$, #Inside transform?
       test = opinfo(15332, 0, 0010)
       *test, e$
EDIT: Actually param 15332 is work offset numbering type, but that's what I am trying to get, despite misleading topic.
EDIT2: I don't get it. Now it mysteriously started to work, despite code being exactly the same, and operations being exactly identical. Is it possible that Mastercam fails to reload the modified/updated post processor file into memory for some reason (it is on network drive) which can cause glitches?!
Did you copy and paste that code from your editor?  If so you have some extra junk after the 15332, see below.
Once I removed the extra characters everything worked as expected.
Yes I did. That was observant! And that explains everything. AND, this is a recipe for disaster. If Mastercam Code Expert messes with my post with invisible junk, crashes are bound to occur.
