Vbscript to chain entities on inside and outside closed chains and drill based on level
Soo, I've been working on a vbscript to auto assign toolpaths based on the toolpath door example and another drilling example. I would definitely like to expand it further to read the z depth of entities and pass that into the overrides not sure if that's possible. Also for some reason when I try to assign a drill toolpath to edge curve instead of circle centerpoints the points are translated into the mirror position of the x Axis so in the Y- region. Here's what I've come up with so far.It has been saving me a lot of time chaining and selecting points.
' -- Operations library
Const DEF_OPERATIONS_LIB = "ProgramHalfInchPanelWDrill.mcam-operations"
Const OP_FILE = "C:\Users\Public\Documents\shared Mcam2018\mill\Ops\ProgramHalfInchPanelWDrill.mcam-operations"
' -- Operation comments for each operation saved
Const OP_NAME_DRILL = "Drilling Operation"
Const OP_COMMENT_DRILL = "Drilling Operation"
Const DEF_OP_OUTSIDE_FINAL_CONTOUR = "OUTSIDE FINAL CONTOUR OSCILIATE"
Const DEF_OP_OUTSIDE_FINAL_CONTOUR_TWO = "OUTSIDE FINAL CONTOUR TOP TWOD"
Const DEF_OP_OUTSIDE_FINAL_CONTOUR_THREE = "OUTSIDE FINAL CONTOUR"
' -- Level numbers
Const DEF_DRILLPOINT_LEVELONE = 1062
Const DEF_INSIDE_FINAL_LEVEL = 25
Const DEF_OUTSIDE_FINAL_LEVEL = 20
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim strPathToOperations, ovOverRides, strFileName, overrides
Dim FSO
Set FSO = CreateObject("Scripting.FileSystemObject")
If Not IsDrawing Then ShowString "We need a drawing!": Exit Sub
strPathToOperations = GetPathFromExtension("Operations")
strPathToOperations  = AddBackSlash(strPathToOperations) & DEF_OPERATIONS_LIB
If Not FSO.FileExists(strPathToOperations) Then
ShowString strPathToOperations & "not found."
Exit Sub
End If
strFileName = GetCurrentFileName
Set overrides = New McOverride
With overrides
.FeedRatePercentOn = False
.FeedRate = 80
.SpindleSpeedPercentOn = False
.SpindleSpeed = 80
End With
Set ovOverRides = New McOverride
With ovOverRides
.DepthOn = False ' -- Override operation depth?
.Depth  = -.125 ' -- New depth If DepthOn = True
.FeedRatePercentOn = True ' -- New feed rate Is a percentage?
.FeedRate = 80
.SpindleSpeedPercentOn = True ' -- New spindle speed Is a percentage?
.SpindleSpeed= 80 ' -- New spindle speed If SpindleSpeedOn = True
End With
' * Drill all arcs on our DEF_DRILLPOINT_LEVELONE level
Call ZeroPts
Dim success
success = StartDBSearch(mc_alive, mc_arctype)
If success Then
Do
If Not DEF_DRILLPOINT_LEVELONE <> GetEntityLevel Then
Dim Arc
Set Arc = New McAr
If GetArcData(GetEntityEptr, Arc) = True Then
Call AddDrillPoint (Arc.X, Arc.Y, -1)
End If
End if
Loop While NextDBSearch
End If
If MakeOperationFromName(OP_FILE,OP_NAME_DRILL,OP_COMMENT_DRILL, overrides) <> mcOPERATION_INVALID Then
Else
ShowString("Could not apply Drilling toolpath")
End If
Call ZeroPts
' * Chain all entities on our INSIDE_FINAL_LEVEL level planes set to bottom to chain left cutter comp closed chain
Call SetTPlaneNumber(mcVIEW_BOTTOM)
Call SetCPlaneNumber(mcVIEW_BOTTOM)
If ChainAll(True, False, DEF_INSIDE_FINAL_LEVEL, vbNullString) Then
If MakeOperationFromName(strPathToOperations,DEF_OP_OUTSIDE_FINAL_CONTOUR,DEF_OP_OUTSIDE_FINAL_CONTOUR, ovOverRides) <> mcOPERATION_INVALID Then
If MakeOperationFromName(strPathToOperations,DEF_OP_OUTSIDE_FINAL_CONTOUR_TWO,DEF_OP_OUTSIDE_FINAL_CONTOUR_TWO, ovOverRides) <> mcOPERATION_INVALID Then
If MakeOperationFromName(strPathToOperations,DEF_OP_OUTSIDE_FINAL_CONTOUR_THREE,DEF_OP_OUTSIDE_FINAL_CONTOUR_THREE, ovOverRides) <> mcOPERATION_INVALID Then
Call GetReady
Else
Call GetReady
End If
Else
Call GetReady
End If
Else
Call GetReady
End If
Else
ShowString "Could not chain INSIDE FINAL level"
End If
' * Chain all entities on our OUTSIDE_FINAL_LEVEL level, planes set to top to chain left cutter comp outside closed chain
Call SetCPlaneNumber(mcVIEW_TOP)
Call SetTPlaneNumber(mcVIEW_TOP)
If ChainAll(True, False, DEF_OUTSIDE_FINAL_LEVEL, vbNullString) Then
Call GetReady
Else
Call GetReady
End If
Else
Call GetReady
End If
Else
Call GetReady
End If
Else
ShowString "Could not chain OUTSIDE FINAL level"
End If
Exit Sub
End Sub
' Function Declaration
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
' Sub Declaration
Public Sub GetReady
Call FreeChains
Call UnselectAll
Call RepaintScreen(True)
End Sub
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "\" Then sPath = sPath & "\"
AddBackSlash = sPath
End Function
  • 4 weeks later...
I found a solution i guess apparently when i created curve edges in 3D mode the returned x y or z values were wrong. Also I did manage to create alter the operation depth dynamically based on the chained entity position and sort different holes sizes automatically and chain them as well, i'm so blown away by what is possible with such simple languages as vbscript and vb.net.
