Pallet unclamp between toolpathe
Trying to work a little voodoo on my generic fanuc 4 axis post. Just did a job where I needed to go from a standard contour toolpath to a 5 axis curve. The contour toolpath is a linear ramp move to get the tool down to the correct Z and the starting X position of the curve toolpath. My issue is that I need to unlock the B axis before the machine can rotate and the post doesn't do it so I edited the program so I could get the program to the operator. Now that I have time I want to fix the post so it'll output the unclamp code before the B rotates. I have my post set up right now so if the 5 axis toolpath is the 1st operation it won't post the lock code after the B rotation, but I cannot figure out where to put the code so the post unlocks the B before the 5  axis.
Any idea on where in the post I need to put my  "if" statement? Been a long day already and probably just not seeing things correctly.
Thanks.
I achieved this using canned text
" if cantext$ = 6, strcantext =  strcantext + "M46"
        if cantext$ = 7, strcantext =  strcantext + "M47""
        <canned_text>
            <canned_text_1>
                <text>Stop</text>
            </canned_text_1>
            <canned_text_2>
                <text>Ostop</text>
            </canned_text_2>
            <canned_text_3>
                <text>Bld on</text>
            </canned_text_3>
            <canned_text_4>
                <text>bLd off</text>
            </canned_text_4>
            <canned_text_5>
                <text>S6000 In Cycle Speed Change</text>
            </canned_text_5>
            <canned_text_6>
                <text>M46 (TABLE UNLOCK)</text>
            </canned_text_6>
            <canned_text_7>
                <text>M47 (TABLE LOCK)</text>
            </canned_text_7>
            <canned_text_8>
                <text>M8</text>
            </canned_text_8>
            <canned_text_9>
                <text>M9</text>
            </canned_text_9>
            <canned_text_10>
                <text>M10</text>
            </canned_text_10>
        </canned_text>
Something else I probably should have mentioned is that the tools ends at the same spot as the start of the 5 axis toolpath so all the post/tool does is at the end of the contour toolpath is to rapid the tool to my clearance plane then brings the tool right back down without moving the X,Y or B.
Oh and another thing is that all of my planes are set to use the same work offset, which I think is where my problem is coming from.
Edited by BBprecise
47 minutes ago, Old_Bear said:
A change of operation should still run it through the null tool change block
As such, the canned text can still work
It very well may Bear, just haven't tried your suggestion yet. Other fires to put out 1st. 😁
I ended up getting the post to do what I needed with the exception that it's posting an extra unclamp code, but I can deal with that as I don't use 5 axis curve very often. Better to have it then not. Ended up having to add what I needed to the prapidout section of post. Maybe someday I'll fix the double unclamp code but that's for another day.
Thanks for the suggestions guys.
