How to rotate a axis for contour path
Seedy steve
OK, I don't think I am seeing what you're expecting...to me, it looks like it chanfers straight across the edge...
Are you trying to run it like a C axis contour in a lathe? If so, you'll need a multi-axis path to achieve that...
O0000 (1)
(MCX FILE  - C:\USERS\JOHN\DESKTOP\BACKUP.MCAM)
(PROGRAM   - 1.nc)
(DATE      - MAY-11-2019)
(TIME      - 9:43 AM)
(T1   - 3/8 SPOT DRILL       - H1   - D1   - D0.3750")
N100 G00 G17 G20 G40 G80 G90
N110 G91 G28 Z0.
N120 (COMPENSATION TYPE - COMPUTER)
N130 T1 M06 (3/8 SPOT DRILL )
N140 G00 G17 G90 G54 A-360. X.8085 Y0. S2200 M03
N150 G43 H1 Z1.749 M08
N160 Z1.564
N170 G94 G01 Z.749 F23.
N180 A0. F1759.42
N190 Z.799 F333.
N200 G00 Z1.749 M09
N210 M05
N220 G91 G28 Z0.
N230 G28 Y0. A0.
N240 G90
N250 M30
I only have 2019 check these settings and set your planes to Top/Top
N160 Z1.564
N180 A0. F1759.42
N190 Z.799 F333.
N200 G00 Z1.749 M09
N210 M05
N220 G91 G28 Z0.
N230 G28 Y0. A0.
N240 G90
N250 M30
My code looks the same but the 4th is taking the shortest route to the next A so it turns about 2 deg.
I tried fooling it with overlap by circumference and by extend length of contour but no go.
here it is.
N110 G91 G28 Z0.
N140 G00 G17 G90 G54 A-364.303 X.976 Y0. S2200 M03
N160 Z1.564
N170 G94 G01 Z.728 F23.
N180 A-360. F1810.17
N190 A0.
N200 A2.295
N210 Z.778 F333.
N220 G00 Z1.749 M09
N230 M05
N240 G91 G28 Z0.
N250 G28 Y0. A0.
N260 G90
N270 M30
What I ended up doing was to stick a g91 in ahead of my A360. and a G90 in the next line. it worked well.
I think my machine is set up to take the shortest way to the next A value.
by looking at these codes I suspect they will produce the same non turning result.
I will see next time I have the fourth running. Thank you for your time Jason and Heavy Chevy
