Threadmill Operation Bug? WIerd quirk
Metallic
Hey all. So I just scrapped a critical part on my machine because of a crazy threadmilling quirk. Something Ive never seen happen.
I use my Harvey thread mill. I copy/paste the operation and copy/paste the tool in order to change the diameter (new tool number as well), but keep the original tool unchanged in case i need to come back to it.
BUT. Mastercam CHANGED THE PITCH back to the default 0.05 for no reason. I just recreated the issue, simply by changing to a different diameter tool, Mastercam has changed the pitch back to default 0.05. I changed no other parameters.
Anyone ever had this happen before? Or am I missing something?
Thanks!
Threadmill has had some really weird stuff for a couple versions of Mastercam.
In 2017, if you used "Incremental" for the Linking Parameters, it will treat the "Depth" as an actual 'Incremental from Geometry' value, and the Top of Stock as 'Incremental', but the Retract and Clearance values are Absolute values. So if you enter "0.25" for Retract, thinking "that will be .25 above my Geometry", nope, that's 0.25 Absolute!
This pitch bug cost me an M36 hole in a $90,000 forging and egg on my face when I had to tell a customer and then do a work-around.  At least it was an extremely high pressure hydraulic manifold that only weight about 24k lb and was 4340 forged so we couldn't weld it.
Since then, I find myself spending more time checking threadmill paths than making them.  Also I always take a quick look at the posted code and then calculate the pitch again to make sure posted code is correct.  I also set my pitch in my threadmill tool definitions EXACTLY.  Your defaults can also mess with this as that's where that 0.05 comes from.  My most common thread was an M36 so I set my default to that.  No way of knowing how many times that helped me but I'm sure it did at least a few.
I hate how this tool path treats pitch and the number of teeth setting
I recently sent a bad thread mill path to the floor for a very expensive part
Fortunately for me, the operator is old old school and trusts nobody
He ran my code though his calculator and called me on it.
Just changing the feed rate on a tool can change the number of teeth setting and scrap a part
Sorry, I just re-read this, and I don't think it's the same thing that was discussed previously.  Can you send a file into QC including which version you're experiencing this in?  I can't replicate your behavior from scratch.  I tried in 2019 & 20.
Here's how I did it.  I set up a Threadmill op on a Ø.500" circle, and defined a Ø.25" 24 TPI single point thread mill.
I then copy/pasted the toolpath, edited the tool to increase diameter to .375" and the tool number to 2, while still leaving a 24 TPI and 1/24th as the flute length:
No matter what I do, my cut parameters don't update:
What did I do wrong?
I think they are setting the pitch in the thread mill field and not in the tool.
So if you click the tool it resets the field to match the tool value
I use a lot of single-profile threadmills, so I can cut a 10-32 and a 10-24 with the same tool.  If I defined it as a 24 pitch and use it to cut a 32 pitch, then any time I change something about the tool the operations that use it will change to 24 pitch.  Similarly if I'm using a 1/4-28 multi-profile threadmill to cut a dual lead 1/4-14, touching the tool will revert it to 28 pitch.
As Leon said, I was using my "Thread Pitch" in the operation manager instead of in the tool dialogue window.
As a previous poster said....what if I wanted to use a single point threadmill to cut two separate thread pitches in the same program?
In mastercam 2019
Who should I forward this file to?
Wheel_Nut.ZIP
