piaofcu
Can NETHook get an operation's cycle time?
Hi,
   I want to get some operation's parameter.  “NETHook” can get many parameter simple, like operation type、tool information... but some parameter i can't find, like cycle time,XY /Z stock to leave. (like "setup sheet report" )
   How can  i get the operation's cycle time?  (X9)
  Thank you.
Thanks very much!  I will try it later if we upgrade to 2020.
On 6/10/2019 at 8:34 PM, Roger Martin from CNC Software said:
In the NET-Hook API  for Mastercam 2020 there these CalcCycleTime methods -
Operation.CalcCycleTime
OperationsManager.CalcCycleTime
There is another question.
If the toolpath is created in incremental mode (contour), then will get  "linking.DepthIncremental"  - True
Is there any way to calculate the ABS value? (incremental to absolute)
use back plot and look for more info... the drop down.
The value you get from a specific property in the LinkingParams of an operation,
is just the "value". It is not an incremental/absolute value, it's just a "value"
The true/false setting of the DepthIncremental (in the case of Depth) tells the system how to "look at" the (Depth) value.
If "linking.DepthIncremental"  = True
Then it is incremental "from somewhere else", such as Top Of Stock.
Experiment with a simple 2D-Contour path, changing just the DepthIncremental and see what the Depth value is in each case.
Thank you for replying, I want to get this parameter in NEThook, but I did not found information about “back plot”  in NEThook.
I think maybe I didn't express it clearly.
There is a 2D-Contour path: Only select one Chain , Z coordinate is -5.0  (absolute value) .
 The Contour path setting :   depth value is -4.0 , Incremental mode ---> Then the absolute value of the cut depth is -9.0
In VS, get information about this operation: "linking.DepthIncremental" = True, "linking.Depth"="-5."
Now, if I want to get the abs value of this operation (-9.0),  Is there any way?
I thought about calculating the depth of the entity + Incremental depth  value,But it seems not easy to achieve.
back plot is in mastercam idk about net hook. toolpath manager, select all tool paths, find backplot icon ... open drop down.
Posted (edited)
Not with doing the calculation yourself.  There are not  separate incremental and absolute values stored in the operation's data.
Edited by Roger Martin from CNC Software
Okay, I understand.
I try "Operation.GetMinimumZ" Method  gets the minimum Z .
The document is described as such: Gets the minimum Z coordinate (from the binary NCI) ...
No matter whether I save NCI file first or not, I always get the minimum value allowed in a Double.
Or "the binary NCI" is not the way to save NCI?
33 minutes ago, Roger Martin from CNC Software said:
And unfortunately, I see that the GetMaxAndMinZ method was broken until Mastercam 2019.
This is really a bad news.
By the way,In Visual Studio breakpoint mode, I can see a lot of operation member, As shown “PIC-1"
Can I access them?  If i access it directly, the error "Not operation member" is displayed. "PIC-2"
Roger,
Thank you very much for your patience.
About the previous question, I found a solution myself.
I will come back to ask if there are other problems.
Thanks again!
