Line Numbering
Forgive me if this topic has already been discussed, but I couldn't find specifically what I wanted. So I'm trying to figure out how to number more than just tool change lines....maybe just some lines, maybe all lines, I don't know. I googled it first, and came up empty. Any help would be appreciated.
There have been a couple of threads on variations in line number output. It will require moderate to extensive post editing depending on what you want to do.
All lines is easy, it is one of the options in mpmaster. Look in the general output settings in the  post :
tseqno           : 1           #Output sequence number at toolchanges when omitseq = yes
                               #0=off, 1=seq numbers match toolchange number, 2=seq numbers match tool number
There is also a switch in the CD to omit sequence numbers (read above notes for this variable)
On 6/28/2019 at 12:28 PM, Lazarusman said:
Is there any way to number operations that use the same tool?
If you look at option 2 above you get the tool number as the sequence number.
I believe there was a thread that added a trailing number to indicate which toolchange for that tool you are on. So N202 would be the second time T2 was called.
Anything but the 3 options listed above (plus numbers on ALL lines in CD switch) will require post editing.
