VMC 4 axis feed not correct
RICARDO_GOMES
From the calculations i did real quick, The feeds are close to a machine running non cylindrical/polar tool paths (g107/g112..etc) on a 26.054 diameter part.
When we have operators question the feed rates on our lathes during a milling operation, we use the attached pdf to give a general idea of how the post calculates the correct feed to match ipm/diameter/..etc.
If the machine does use a cylindrical/polar tool path, then the f1000. that you have programmed would be seen as f1000.
Hope this helps some.
feed rate for rotary tables.pdf
Thank you.
However, feeds for rotary paths are never posted on a knowledgeably way . Today i have found the arc filter/tolerance afecting it all the way. Problem is, i never know the values that will be posted and have to try tenths of times to adjust all the tool feeds and arc filter/tolerance until it gets aceptable values. It should exist a easyear way to do this.
