Sign in to follow this
odessa
custom cycle for probe
Hello.
How to use custom drill cycle for renishaw probe.
Thanks in a forward.
9 minutes ago, odessa said:
Hello.
Do you have HAAS or FANUC?  I just completed the ENTIRE probing in the drill cycle$ 19, let me know. I will paste my codes for you.  I have HAAS and FANUC.
What is your email?  I will send you the codes
On 8/2/2019 at 3:54 PM, odessa said:
Here it is...
#Region pdrlcst$         # First hole
   if loop_var,
      pdrlcommonb
      #if depth$ < zero & refht$ < zero,
        #prntdd = depth$ + abs(refht$) #Calculate total cutting depth
      #else, prntdd = depth$ + refht$ #Calculate total cutting depth
      #if prntdd <> min_depth, "(", no_spc$, *prntdd no_spc$, ")", e$ #prntdd= .XXXX)
      if drillcyc$ = 8, prigid_tap  #Rigid Tap
      if drillcyc$ = 9, pdrlcst10   #Pitch Tap
      if drillcyc$ = 10, pdrlcst12  #Mazak Tap
      if drillcyc$ = 11, pdrlcst11  #Fadal Tap
      if drillcyc$ = 12, pGunDrill #Gun Drilling Mode
      if drillcyc$ = 13, PG1Drill  #G1 Feed In/Out Drill Mode
      if drillcyc$ = 14, pAircraftDrill #Aircraft Drilling
      if drillcyc$ = 15, pOtherGunDrillMode #
      if drillcyc$ = 19, Probings
      pcom_movea
#Region pdrlcst_2$
pdrlcst_2$       #Custom drill cycles 8 - 19, additional points (user option)
   if loop_var,
      #Use this postblock to customize drilling cycles 8 - 19
      if drillcyc$ = 8, pdrill_2$
      if drillcyc$ = 9, pAkiraSeiki #Mitsuibishi Tap Second Point
      if drillcyc$ = 10, PMazakTapCode
      if drillcyc$ = 11, pFadalTapCode
     if drillcyc$ = 19, ProbingsTOOL.thumb.png.2f50b097fd919c40c3119216d07c2125.png451835201_HAASPROBE.thumb.png.d026255cfc396b36b3973b43af644d4a.png
      pcom_movea
   else, pncoutput_drl
#Region Probings
Probings
 #Z SURFACE FIND, A20.,
 #"DRILL TOP OF STOCK: ", ~tosz$, e$
 #"DRILL CLEARANCE: ", ~zdrl$, e$
 #"DRILL CLEARANCE: ", ~initht$, e$
 #"DRILL RETRACT: ", ~refht$, e$
 #sDrillHalfClearance = zdrl$/2
  if initht$ > 0 & refht$ > 0 & (tosz$ > operation_depth) & old_mr7  = 1, #HAAS Probe
   if drillcyc$ = 19 & peck2$ > 0 & peckclr$ = 0 & retr$ = 0 & dwell$ = 0 & shftdrl$ = 0,
     sDrillTopOfStock = tosz$ + depth$ + TipCompAmountProbe
     pbld, *refht$, no_spc$, "(Z SURFACE FIND)", e$
     "G4 P5.(5S SAFETY STOP)", e$
     #pbld, *sDrillTopOfStock, e$
     pbld, "G1", *sDrillTopOfStock, *feed, e$
     *tosz$, no_spc$, "(PROBE LIGHT MUST TURN ON)", e$
      if OriginNumber > 0 & OriginNumber < 6,
       g_wcs = workofs$ + 54 + UserOrigin
       sHaasProbeWorkOffsetNumber = g_wcs
      sProbeProgramnumber = peck2$
      if g_wcs = 54, sG10ProbeWorkOffsetNumber = 1
      if g_wcs = 55, sG10ProbeWorkOffsetNumber = 2
      if g_wcs = 56, sG10ProbeWorkOffsetNumber = 3
      if g_wcs = 57, sG10ProbeWorkOffsetNumber = 4
      if g_wcs = 58, sG10ProbeWorkOffsetNumber = 5
      if g_wcs = 59, sG10ProbeWorkOffsetNumber = 6
      if TipCompAmount > 0 & TipCompFeature = 1, sHaasProbeDepth = (depth$ + TipCompAmount) * (-1)
      if TipCompFeature = 0, sHaasProbeDepth = depth$ * (-1)
      if TipCompFeature = 1, sHaasProbeDepth = depth$ * (-1) - TipCompAmount
      sHaasProbeDepth = (operation_depth * (-1) - (tldia$/2)) - tosz$
      TipCompAmountProbe = TipCompAmount * (-1)
      QCWorkOffSetNumber = peck1$
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A20.", *sHaasProbeDepth, e$
      if TipCompFeature = 1, "G91 G10 L2", *sG10ProbeWorkOffsetNumber, no_spc$, "(", no_spc$, *g_wcs, no_spc$, ")", *TipCompAmountProbe, no_spc$, "(INCREMENTAL)", e$
      "G0 G90", *initht$, e$
      TipCompAmountProbe = TipCompAmount * (-1) * (-1)
    !old_mr7
  #Rectagnle Block - A13.
  if initht$ > 0 & refht$ > 0 & tosz$ > 0 & depth$ <> 0 & old_mr7  = 1, #HAAS Probe
   if drillcyc$ = 19 & peck2$ > 0 & peckclr$ = 0 & dwell$ > 0 & shftdrl$ = 0,
    if retr$ > 0 & dwell$ > 0  | (refht$ > 0 & retr$ > 0 & dwell$ > 0 | retr$ = dwell$),
     pbld, *refht$, no_spc$, "(RECTANGLE BLOCK)", e$
     pbld, "G1", *sDrillTopOfStock, *feed, "(PROBE LIGHT MUST TURN ON)", e$
      sXProbeValue = retr$
      sYProbeValue = dwell$
      if depth$ > 0, sHaasProbeDepth = tosz$ + depth$
      if depth$ < 0, sHaasProbeDepth = (tosz$ * -1) + depth$
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A13.", *sXProbeValue, *sYProbeValue, *sHaasProbeDepth, e$
      "M0(COMPARE 10188 MACRO - PRINT VALUE)", e$
    !old_mr7
  #Rectangle Pocket - A12.
  sProbeDepth = tosz$ - operation_depth
  if initht$ > 0 & refht$ > 0 & tosz$ = 0 & old_mr7  = 1, #HAAS Probe
   if drillcyc$ = 19 & peck2$ > 0,
    if peckclr$ = 0 & dwell$ > 0, shftdrl$ = 0 | (retr$ = 0 & dwell$ > 0 | retr$ = dwell$),
     if depth$ <> 0,
      sDrillHalfClearance = initht$ - 2
      sProbeRectangularPocketDepth = (initht$/2) - depth$
      "G65 P9832(PROBE ON)", e$
      pbld, *refht$, no_spc$, "(RECTANGLE POCKET)", e$
      pbld, "G1", *sDrillHalfClearance, *feed, no_spc$, "(SAFETY APPROACH)", e$
      pbld, "G1", *depth$, *feed, no_spc$, "(PROBE LIGHT MUST TURN ON)", e$
      "G4 P5.(5S SAFETY STOP AGAIN)", e$
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A12.", *sXProbeValue, *sYProbeValue, e$
    !old_mr7
  #X Pocket - A15.
  if initht$ > 0 & refht$ > 0 & tosz$ = 0 & depth$ <> 0 & drillcyc$ = 19 & peck2$ > 0 & old_mr7  = 1, #HAAS Probe
   if peckclr$ = 0 & dwell$ = 0 & shftdrl$ = 0,
    if retr$ > 0,
     pbld, *refht$, no_spc$, "(X POCKET)", e$
     pbld, "G1", *depth$, *feed, e$
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A15.", *sXProbeValue, e$
    !old_mr7
  #Y Pocket - A17.
  #X Pocket - A15.
   if peckclr$ = 0 & retr$ = 0 & shftdrl$ = 0,
    if dwell$ > 0,
     pbld, *refht$, no_spc$, "(Y POCKET)", e$
       sHaasProbeWorkOffsetNumber = g_wcs + 1
       else,
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A17.", *sYProbeValue, e$
    !old_mr7
  #Web X Axis - A14.
  if initht$ > 0 & refht$ > 0 & tosz$ > 0 & depth$ <> 0 & drillcyc$ = 19 & peck2$ > 0 & old_mr7  = 1, #HAAS Probe
    if retr$ > 0 & tosz$ > 0,
     pbld, *refht$, no_spc$, "(WEB X-AXIS)", e$
      if depth$ < 0, sHaasProbeDepth = (tosz$ + depth$)
      if depth$ > 0, sHaasProbeDepth = (tosz$ - depth$)
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A14.", *sXProbeValue, sHaasProbeDepth, e$
    !old_mr7
  #Web Y Axis - A16.
    if dwell$ > 0 & tosz$ > 0 & old_mr7 = 1, #HAAS Probe
     pbld, *refht$, no_spc$, "(WEB Y-AXIS)", e$
      if depth$ > 0, sHaasProbeDepth = tosz$ - depth$
      if depth$ < 0, sHaasProbeDepth = (tosz$ + depth$) * -1
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A16.", *sYProbeValue, sHaasProbeDepth, e$
    !old_mr7
  #Bore - A10.
  if initht$ > 0 & refht$ > 0 & (tosz$ = depth$ |tosz$ < depth$) & old_mr7  = 1,
   if drillcyc$ = 19 & peck2$ > 0 & peckclr$ = 0 & retr$ = 0 & dwell$ = 0,
    if shftdrl$ > 0,
     sDrillHalfClearance = initht$/2
     pbld, *refht$, no_spc$, "(BORE)", e$
      sProbeDiameterValue = shftdrl$
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A10.", *sProbeDiameterValue, e$
    !old_mr7
  #Boss - A11.
  if initht$ > 0 & refht$ > 0 & tosz$ > depth$ & old_mr7  = 1, #HAAS Probe
    if shftdrl$ > 0,
     pbld, *refht$, no_spc$, "(BOSS)", e$
     pbld, "G1", *tosz$, *feed, e$
      if depth$ < 0, sHaasProbeBossDepth = ((tosz$*-1) + depth$)
      if depth$ > 0, sHaasProbeBossDepth = (tosz$ - depth$)*-1
      "G65", *sProbeProgramnumber, [if peck1$ > 0 & drillcyc$ = 19, *QCWorkOffSetNumber, else, *sHaasProbeWorkOffsetNumber], "A11.", *sProbeDiameterValue, *sHaasProbeBossDepth, e$
   !old_mr7
      pdrlcommonb
      pbld, pdrlxy, e$
      pcom_movea
#EndRegion Probings
# Start of File and Toolchange Setup
psof0$           #Start of file for tool zero
      psof$
old_tloffno : 0
old_mr7     : 0
old_mr9     : 0
old_mr10    : 0
pmisc_to_old      #
     old_tloffno = tloffno$
     old_mr7     = mr7$
     old_mr9     = mr9$
     old_mr10    = mr10$
     g10tl_len   = mr9$
     g10tl_dia   = mr10$
pdump$        #
     #"pdump$", ~prmcode$, ~sparameter$, e$
If I can offer a critique...
I hope it's taken in the way I mean it...
Sharing your work is awesome....no doubt....
The big problem I see with what you've done in this work, you've tied too much into one custom cycle....it's going to be confusing to someone else, other than the person who wrote it. That person understands what they were trying to do and how they went about it.
When you're editing posts, I try to remember that it might not be me that's using something in 3 years....if I leave a company with good, proven posts but the next person has no clue how to use it....in their eyes, since they cannot get good code out, it's a crappy post that doesn't work.
So simplify, assume it's not for you. Make it easy for the next person to understand, document, document, document.
Again, please accept this in the manner meant  :cheers:
Again, please accept this in the manner meant  :cheers"
Good morning Old_Bear,
   I agree with you with certain points.  I've been running a lot of machines and that is why I am writing a UNIVERSAL POST.  I have worked with HAAS and FANUC closely to come up with a way that one post works for all.  I know it is very confusion but... but..., but I also have ALARM MESSAGE.  If people doing wrong it won't post, I haven't showing up in this forum for the alarm message yet since it it tool long but I think it is worth it to let the post double check my work, especially speaking of probings system.
Best regards,
   S.Luong
Good Morning, Pc robotic.
Thank you very much
Could you email me your creation about custom drill cycle for probe.
Thank you again.
All the best
Thank you very much
Thank you again.
All the best
Hi Odessa,
   I would be the same code as I pasted.  I am apologize for not sending the entire post since it is not allowed in this forum.  I think from this portion of these codes, they would pretty much help you to get you going with the HAAS probe because I successfully made it and ran it more than 6 months already.
PS: I am sorry that I have asked your email and not sending the codes thru your email since I got "warned" long time ago for given free .PST file to other members.
S.Luong
