Sign in to follow this
opcode
M01 after every OP
How do I insert M01 for postprocessor?  optional stop after every operation for the SAME tool, without keying it into the code? (Manual Entry)
The op_id$ value is the key to this.  op_id$ is the unique identifier for an operation in the Mastercam database.
There is more than one way to do this.  I typically set up a boolean constant called is_new_op that checks the value of op_id$ to the prv_op_id$.  Then in the null tool change postblock I use is_new_op to determine whether or not to output the op stop code. Some pseudo code below
  1. is_new_op = fsg(op_id$ <> prv_op_id$, yes$, no$)
  2.
  3. ptlchg0$
  4.     if is_new_op, "M01", e$
  5.     !op_id$
Depending on how your post is setup you may have to change when op_id$ is updated with the '!' modifier.
4 hours ago, jeff.D said:
...Some pseudo code below
  2.
  3. ptlchg0$
  5.     #!op_id$ - this in incorrect, see below.
I realized after posting that updating op_id$ in null tool change will not work.
  2.
  3. ptlchg0$
  5.
  6. ptlchg$
  7.     !op_id$
Depending  on how your post is setup you may have to change  w h en op_id$ is updated with the '!' modifier .
  2.
  3. ptlchg0$
  5.
  6. ptlchg$
  7.     !op_id$
Hello Jeff.D,
  I would like do to this as "M0" instead of "M01", is that possible?
If previous OP_ID$ is MANUAL ENTRY DATA AS CODED, then output "M0" instead of "M01".
Is that possible, Jeff.D?
Thank you for sharing.
  2.
  3. ptlchg0$
  5.
  6. ptlchg$
  7.     !op_id$
Hello,Jeff.D
          When I  edit it ,  I find it is difficut to me for completing the "M01", I get some err. How to get it ,I want to get the result.
Thank you for  helping!
