Sign in to follow this
PcRobotic
Plunge FeedRate
Good afternoon everyone,
   I am trying to write out an alarm of which "IF FEED <> PLUNGE, then alarm".  I don't have the right parameter I think.  Would you guys point out me the right direction to correct my mistake on this...?
FeedRatePlunge: 0
#Region sPlungeFeedCheck
sPlungeFeedCheck = "CUT# "+sToolPathNumber+", FEEDRATE and PLUNGERATE should be the same"
                   +no2asc(13)+"TOOL#"
                   +no2str(t$)+" ("+no2str(tldia$)+", "+s20001+")"
                   +no2asc(13)
                   +no2asc(13)+"FeedRate         =====> F"+no2str(feed)
                   +no2asc(13)+"Plunge Rate    =====> F"+no2str(FeedRatePlunge)
                   +no2asc(13)
                   +no2asc(13)+"Do these following step:"
                   +no2asc(13)+"Step 1 = Click on PARAMETERS"
                   +no2asc(13)+"Step 2 = Click on TOOLS tab"
                   +no2asc(13)+"Step 3 = Look for FeedRate        =====> F"+no2str(feed)
				   +no2asc(13)+"Step 4 = Look fore FeedRate      =====> F"+no2str(FeedRatePlunge)
				   +no2asc(13)+"Step 5 = They both should be the same."
                   +no2asc(13)
                   +no2asc(13)+"                                               OK to proceed posting."
                   +no2asc(13)+"                                               CANCEL to abort posting."
#EndRegion sPlungeFeedCheck
fmt "" 2 FeedRatePlunge
           if FeedRatePlunge <> feed & opcode$ <> 3, [if mprint(sPlungeFeedCheck, 2) = 2, exitpost$] #End Mill Bull No Break Through
pparameter$ # Run parameter table
     if prmcode$ = 10031, FeedRatePlunge = rpar(sparameter$, 1)
Hello,
The parameter is correct.  I think your issue is that you are not rounding the values to their respective formats before the comparison.
I believe that Jeff is correct.
If you embed the 'format round' function into the 'if' statement, it will 'round' the current value, before it compares it with the 'feed' variable.
Note that 'feed' may have a different 'fs2' "number" tied to it, depending on if you are in 'feed per minute' or 'feed per revolution'. In other words: there are places in the post where 'newfs' might be applied to 'feed'. You'll need to search the post for 'feed', and might need to use 'newfs' function on the 'FeedRatePlunge' variable, in addition to using 'fmtrnd'. The "format round" function will currently round 'FeedRatePlunge' to '4 decimal place output'. Why? because your 'format assignment' line (fmt) has a value of '2', and '2' is the default standard output.
if fmtrnd(FeedRatePlunge) <> feed & opcode$ <> 3, [if mprint(sPlungeFeedCheck, 2) = 2, exitpost$] #End Mill Bull No Break Throug
By default, in MPMaster, the 'feed' variable has a Format Assignment of '15', which I believe is 2 place rounding.
So, you will either need to change this:
to this:
fmt "" 15 FeedRatePlunge
Or, you will need to use a line above the 'if' statement, to apply the correct 'Format Statement', prior to executing 'fmtrnd'!!!
result = newfs(FeedRatePlunge, 15)
to this:
Thank you Colin, it works perfectly.
Thank you Colin, it works GREAT.
