c++
Adding solid data to fbm Mill Using C-Hook for Mastercam 2018
Hi all,
So I found and created the fbm mill operation using TP_FBM_POCKET and was able to modify the parameters in FBM_PocketParameters  however I have been unsuccesful so far to add solid data and regenerate the operation without user interaction, is this a possibility using the sdk?
I found some structs that seem related in one of the header files
struct tp_fbm_chn
 493  {
 494  tp_chain chn; //!< chain control entity
 495  int zone; //!< FBM zone #
 496  int type; // Chain Type = PDETECT_CHAIN_OUTER_ALL_WALL, etc.
 497  double min_rad; // Minimum radius of this chain
 498  bool circle; // true = chain is a circle
 499  };
 500
 501 /** toolpath entity - FBM zone control entity */
 502
 503 struct tp_fbm_zone
 504  {
 505  SDETECT_POCKET_DATA data; //!< pocket data
 506  int flag; //!< status flag
 507  int id; //!< record id
 508  int parentId; //!< Id of parent record (-1 if none)
 509  double parentDepth; //!< Depth of parent record (MAXREAL if none)
 510  int sldEntID; //!< Solid entity ID
 511  double baseTaper; //!< Taper angle (outer wall)
 512  double islTaper; //!< Island taper angle
 513  bool taperOK; //!< false = one of the tapers varies or is undetermined
 514  bool containsFillers; //!< true = Filler Lines have been added to some chains
 515  };
So I was kind of leaning toward I need to
init_tp_ent
then
store_ent_assoc
although there is a place in the fbm_pocket_parameters for a solid eptr, there is a lot of material to go through any examples would be a big help.
Peter,
Setting the Solid in the operation is just step #1.
There is a lot  of processing that occurs when you OK out of the FBM Toolpath - Mill dialog.
I have a feeling that accomplishing this detection/processing phase this is not possible via the public SDK.
You can send us your contact/company details and exactly what you're wanting to do to ->  SDK <at> mastercam <dot> com
We can then create a support ticket to investigate further.
Okay, I understand, I was starting to suspect it wasn't easily implemented by the large amount of data related to fbm.I will send an email regarding this particular project.I'm really only trying to find a reliable method to create a silhouette boundary without user interaction. I'm okay with dealing with internal features like pockets and holes so far. Thank you for taking the time to answer.
On 8/26/2019 at 11:25 AM, Roger Martin from CNC Software said:
Peter,
Roger, did you ever find out if the solid detection thing is possible?
